Unable to download firmware for SG300-10
rpoorman
I have tried endlessly even after logging into cisco and it won't download the firmware.  Either it crashes with a page not found or downloads a zero byte file.  I'm trying to set up a lacp/lag link set up and need consistent firmware.
ggrim
Good morning rpoorman,
Thank you for using the Cisco Small Business Support Community. I'm sorry that you're having difficulty downloading firmware for your SG300. I checked the download link available at:
https://software.cisco.com/download/release.html?mdfid=283019611&softwareid=282463181&release=1.4.1.03
And it seems to be downloading correctly on my side. Is this the same link you are using?
I also have found the following links in our Knowledge Base that will hopefully assist you with your configurations on your SG300:
Firmware Upgrade Troubleshooting on 300 and 500 Series Managed Switches
Firmware Upgrade via HTTP/HTTPS on 200/300 Series Managed Switches
Link Aggregate Group (LAG) Configuration on 200/300 Series Managed Switches
I hope that these links are helpful to you!
Best,
Gunner
I was on a Mac, tried it from a windows server and it worked...
