03-15-2023
12:54 AM
- last edited on
03-15-2023
01:09 AM
by
shaiksh
Dear Sir / Ma'am,
We are facing issue with 2 switches, which is model no. as SG350-28P and also Serial Number respectively S/N:- DNI22420B93 & DNI2340052B.
When we put power on the Switches then they up and after taking loan of LAN Network, After that It's down automatically both switches. Kindly take action for this issue ASAP.
Thanks & Regards
Name :- RAJU MISHRA
Contact No.:- 89XXXXXXXX
03-15-2023 03:27 AM
- The particular problem description is vague and unclear , please elaborate, also check the logs on the switches for more insights ,
M.
03-15-2023 06:36 AM
After you adding the device to Switch, Is the switch going down like reboot (both the switches )? or ports going down ?
Also check you have latest firmware, if not upgrade to latest firmware.
if this is emergency reach SMB TAC.
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
