Vlan 1 weirdness
Mike Elliott
Ok I have quite a few of these SG300 switches installed and I can't for the life of me get devices on VLAN 1 to negotiate.  The port comes up but they don't pass any traffic.  In this example I am setting port 9 and port 8 to vlan 1 (the default vlan) and port 10 is my uplink to a Cisco 3750.
The vlan this switch resides on is 100
If I try and add vlan 1 to GE10's trunk, I get
switch222(config-if)#switchport trunk allowed vlan add 1,23,31,66,91,100
VLAN 1 : VLAN was not created by user
If I try add it to the database:
switch222(config-vlan)#vlan 1
VLAN 1: VLAN is occupied for internal usage after reset.
How do I use vlan1 on a port on this ?
Vlan91 is a voice vlan
Here's my full config (sanitized).
config-file-header
switch222
v1.4.7.6 / R800_NIK_1_4_194_194
CLI v1.0
set system mode switch
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 23,31,66,91,100
exit
voice vlan id 91
voice vlan state oui-enabled
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
errdisable recovery cause port-security
hostname switch222
line console
exec-timeout 30
exit
line ssh
exec-timeout 0
exit
line telnet
exec-timeout 30
exit
no passwords complexity enable
username xxx password encrypted blah blah blah
privilege 15
ip ssh server
ip ssh password-auth
snmp-server server
ip http timeout-policy 1800
clock timezone " " -4
clock source sntp
clock source browser
ip domain name versaterm.com
interface vlan 23
 name users
interface vlan 31
 name "Guest Vlan"
interface vlan 66
 name "Demo Vlan"
interface vlan 91
 name Voice
interface vlan 100
 name routing
 ip address xx.xx.xx.xx 255.255.255.0
 no ip address dhcp
interface gigabitethernet1
 spanning-tree link-type point-to-point
 spanning-tree bpduguard enable
 switchport trunk allowed vlan add 91
 switchport trunk native vlan 66
interface gigabitethernet2
 storm-control broadcast enable
 storm-control broadcast level 10
 storm-control include-multicast
 port security max 10
 port security mode max-addresses
 port security discard trap 60
 spanning-tree portfast
 macro description ip_phone_desktop
interface gigabitethernet3
 switchport trunk native vlan 23
interface gigabitethernet4
 macro description guest
interface gigabitethernet5
interface gigabitethernet6
interface gigabitethernet7
interface gigabitethernet8
interface gigabitethernet9
 speed 100
 no negotiation
interface gigabitethernet10
 switchport trunk allowed vlan add 23,31,66,91,100
 switchport default-vlan tagged
exit
macro auto disabled
macro auto processing type host enabled
macro auto processing type switch disabled
macro auto processing type ap disabled
macro auto built-in parameters ip_phone_desktop $max_hosts 10 $native_vlan 23
ip default-gateway <3750 Switch IP>
Rich Uline
Mike,
An internal VLAN is allocated automatically when creating a Layer 3 interface on the switch. You can use 'sh vlan internal usage' to see which interface is using VLAN 1. However, using VLAN 1 isn't really a good idea in the first place and should be avoided if possible.
This is sort of a special case use for this vlan.  We only use it for printers and other admin type things.  How do I enable the use of it?
switch222#show vlan internal usage
Prohibit Internal Usage VLAN list after reset:
Current Prohibit Internal Usage VLAN list:
 VLAN    Usage
 4094    802.1x
switch222#
Ok so I changed the default vlan over to 100, and now layer 2 seems to be working, but I still can't get IP connectivity to the printer.  I've tried setting the port as an access port, to no avail.
This works fine on our catalyst switches
Brain fart, I had set it to DHCP and I was trying to ping the old hardcoded IP
It's working as expected.  Access port in vlan 1, default vlan is changed to 100, backend switch native vlan is set to 100.
