VLAN communication.
mohan90kumar
Two vlans having different domain name but same VLAN ID.These VLANS are created in different switches but connected to diff router ports with trunking enabled. clients in different VTP domains communicating well.
Is communication between these two normal?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
(For the situation you've described) yes (although unsure what VTP pruning might do).
michael o'nan
Level 4
Level 4
same router or two different routers?
