Problems accessing SG300-28P
TonyParrish1053
I have a new SG300-28P, I am unable to connect. After logging in the switch stops at 70% Processing Date. I have try Chrome, IE, and Firefox.
I am not sure of the fireware ver.  I do not want to reset to the factory default because there is no backup and I am not sure of the
configuration.
Tom Watts
Hi Tony, this is going to be purely an issue with the computer/browser, etc.
I;d recommend swapping to a different computer or fully update the one you're using including latest Java.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Your Right. I never thought about that! It's been a really long Day!!!
Thank You! It worked.
Jim Schaefer
I had the same issue and turning off my Kaspersky protection solved it. If you have some internet security running try stopping it and logging back into the switch.
