VLAN Routing
mjaworske
I have a Cisco SG500-52P switch (2 actually, stacked in Layer 3 mode). I have setup Voice VLAN ID2 for our Mitel phone system. I have all ports untagged on VLAN1 and Tagged on VLAN2.  Our IP Scheme on VLAN1 is 10.0.0.x and on VLAN2 is 172.16.16.x. I need to have both networks talk as we have a software app (Xarios) on our computers that needs to talk to our phones. I need help getting the route setup.
5 Replies 5
michael o'nan
Level 4
Level 4
Have you configured ip routing on the switch yet?
Here is a quick setup guide I found
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-switches/885-cisco-switches-sg500-52p.html
Honestly I'm not sure, Are you referring to IPv4 Static Routes?
You have two SVI interfaces on this switch that need to talk to each other. To accomplish this you would need to enter
SG500 (config)# ip routing
This will enable Inter-VLAN Routing
Is there a way to do it via the web interface?
It may be under IP Configuration > IPv4 Interface > tick box IPv4 routing at top of page. Or just console to the switch and type the one command.
