Vlan0 Priority Tag stripped by SG200-08
cjbohl001
Hello All,
My company is currently having issues with the SG 200-08, in that when
we're sending an Ethernet Frame through the switch consisting of an
802.1Q VLAN 0 priority tag and custom payload, the smart switch is
stripping the 802.1Q tag from the frame.
Another Cisco Product, the SG100D-08 Unmanaged Switch will properly
forward the Ethernet frame in its entirety, and exhibits the behavior that we
wish to achieve out of the SG 200-08
Is there any way to configure the SG 200-08 so that it does not strip the
VLAN 0 Priority tag?
Supplemental Info:
  • Switch FW Version: 1.0.1.0
  • Wireshark & port mirroring have been used to verify that the VLAN tag is properly being transmitted to the switch, but removed when going to the targetdevice.
Thanks!
Tom Watts
Hi Chad, 'VLAN tag stripping" is not a configurable feature.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
