01-15-2019 01:42 PM
hello everyone,
I would like to knew haw I kan connect vlan 1 with vlan 2 in the same switch.thank you
01-15-2019 02:23 PM
what is the model of you switch?
01-16-2019 08:24 AM
01-15-2019 02:32 PM
01-16-2019 08:50 AM
I gonna to do it with switcj layer 3,given the vlan ip add en pc getway ,I think it wil be work
01-16-2019 08:59 AM
Hi @soufianams,
To enable the routing functions in the L3 switch, you must enter the command:
S(config)# ip routing
Then, you can review the routing table with the command:
S(config)# show ip route
01-16-2019 02:10 PM
01-17-2019 07:37 AM
Hi @soufianams,
I enclose the exercise with the requirements you mention.
The PacketTracert is version 7.1
