vlan1 vlan 2 conect
soufianams
hello everyone,
I would like to knew haw I kan connect vlan 1  with vlan 2 in the same switch.thank you
7 Replies 7
hisham683
what is the model of you switch?
the switch is 3560 24ps layer3
luis_cordova
Hi @soufianams,
For connect two vlan, you have to do it through a router or an L3 switch.
I gonna to do it with switcj layer 3,given the vlan ip add en pc getway ,I think it wil be work
Hi @soufianams,
To enable the routing functions in the L3 switch, you must enter the command:
S(config)# ip routing
Then, you can review the routing table with the command:
S(config)# show ip route
actualy I have to resolve one task :
"""Using packet tracer version 7.0 or 7.1 you must connect 2 switches with
PAGP aggregation port and create 2 vlan in each switch and make sure only
vlan 1 cannot connect to other switch but can connect to vlan 2 in the same
switch and you must activate rapid, portsecurity and portfast in each
switch.""
but when I active the etherchannel and trunking i kan not make ping from
10.0.0.1 to 10.0.0.2 in the same vlan .I write:
int range f0/10-14
channel-group 1 mode on
int range f0/10-14
switchport mode encapsulation dot1q
switchport mode trunk
after this I kan make ping in the same vlan.
Hi @soufianams,
I enclose the exercise with the requirements you mention.
The PacketTracert is version 7.1
