Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3648 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5333 Views
  • 1 replies
  • 16 Helpful votes
Hi, have here 2*SG550XG as native stack.  Attached are 3* vSphere 6.5 servers, via Etherchannel, redundunt cabeling across the stack members. This works fine. After a FW upgrade the stack unit 2 ran into a boot loop. The good news was that the vSpher...
Hi, I receive a lot of this kind of messages after the last FW upgrade.There is a mgmt acl in place, so this is okay, but what is "interface User Defined Port 1"  and who is 169.254.0.2? Thanks Henri
I'm  trying to find proper OIDs to get status information from SF300-24 24-Port 10/100 Managed Switch.On official documentation I see this:   Object portAdminSpeed   OID 1.3.6.1.4.1.9.5.1.4.1.1.9when I try to snmpwalk  it I 'm getting an error:   SNM...
Drey Tee by Level 1
  • 919 Views
  • 0 replies
Hello, since christmas we have a cluster running with four SG500-52P-K9 V06 switches. Firmware was updated to the latest version 1.4.9.4.Today (luckally in after work hours) Unit 4 of the cluster starting acting up.  SymptomThe system monitoring was ...
NewCom by Level 1
  • 4878 Views
  • 6 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
