Bookmark
Subscribe
1144
vlans dhcp status are not received
ldnnet001
I am configuring vlan on sg300-20 in dhcp mode.
One  vlan that is directed connected to the adsl router get ip address and when I connect host to the ports in this vlan they also receive ip address and can go on internet.
The other four vlans dhcp status are not received.
Kindly help me check this. Thanks
Below is the config log:
switch4ba497#sh running-config
config-file-header
switch4ba497
v1.2.9.44 / R750_NIK_1_2_584_002
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 5,10,20,30,40
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp relay address 192.168.3.1
ip dhcp information option
no boot host auto-config
bonjour interface range vlan 1
hostname switch4ba497
line telnet
exec-timeout 0
exit
no passwords complexity enable
username cisco password encrypted 7af78c911d5b48bea1dc2449d9d89513abeb4be5 privilege
15
ip http timeout-policy 0 http-only
ip name-server  192.168.1.1 192.168.3.1
ip telnet server
interface vlan 1
ip address 192.168.2.254 255.255.255.0
no ip address dhcp
interface vlan 5
name WAN
ip address dhcp
interface vlan 10
name Studio
ip address dhcp
interface vlan 20
name Service
ip address dhcp
interface vlan 30
name Admin
ip address dhcp
interface vlan 40
name Data
ip address dhcp
interface gigabitethernet1
switchport mode access
interface gigabitethernet2
switchport access vlan 10
interface gigabitethernet3
interface gigabitethernet4
interface gigabitethernet5
interface gigabitethernet6
interface gigabitethernet7
interface gigabitethernet8
interface gigabitethernet9
switchport access vlan 20
interface gigabitethernet10
interface gigabitethernet11
interface gigabitethernet12
interface gigabitethernet13
switchport access vlan 30
interface gigabitethernet14
interface gigabitethernet15
interface gigabitethernet16
interface gigabitethernet17
interface gigabitethernet18
switchport trunk native vlan 40
interface gigabitethernet19
switchport access vlan 5
interface gigabitethernet20
switchport trunk native vlan 5
switch4ba497#sh ip int
    IP Address         I/F       Type     Directed   Precedence   Status
                                          Broadcast
0.0.0.0/32          vlan 10   DHCP        disable    No         Not
        received
0.0.0.0/32          vlan 20   DHCP        disable    No         Not
        received
0.0.0.0/32          vlan 30   DHCP        disable    No         Not
        received
0.0.0.0/32          vlan 40   DHCP        disable    No         Not
        received
192.168.2.254/24    vlan 1    Static      disable    No         Valid
192.168.3.102/24    vlan 5    DHCP        disable    No         Valid
switch4ba497#
Also i do not understand why the ip address is 0.0.0.0/32 because the dhcp server ip address is 192.168.3.1
jeffrrod
Level 4
Level 4
Dear Customer,
Thank you for reaching Small Business Support Community.
In Layer 2 system mode, only the management VLAN can be configured with a static or dynamic IP address. In Layer 3 system mode, all the interface types (ports,LAGs, and/or VLANs) on the device can be configured with a static or dynamic IP. Configuring the device to work in either mode is performed in the Administration >System Settings page
When a DCHP Client starts a discovery process, it assigns a dummy IP address 0.0.0.0 before the real address is obtained. This dummy address has the status of “Not Received”.
Pretty much your problem should be solved by changing to Layer3 system mode.  Please let me know if anything comes up and/or if there is any further assistance I may help you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
Thanks for taking time to look into this issue.
The switch is already changed to layer 3 mode before creating the vlans.
If I may ask, will it make any diiference if I use dhcp auto config option or not. Thanks
Dear Customer,
Notice that switching from one system mode to another requires a mandatory reboot, and the startup configuration of the device is then deleted.
By default, the device is enabled as a DHCP client when the Auto Configuration feature is enabled so I would then suggest you to disable it, particularly if you do not have to download configuration files from a TFTP/SCP server.
I'll be looking forward to hear from you and thank you for your time on this matter.
Kind regards,
Hi, thanks for your response on auto configuration.
I attached the screenshots from the router
It is TP-Link Cable/DSL router TL-R860.
Remember the main issue is that only the direct connected (vlan5) on the router get ip address from the dhcp. The other vlans do not get ip address.
when i add port to valn and attche host they can go on internet.
