Dear Lati,
Thank you for reaching Small Business Support Community and for your time and patience regarding your inquiry.
I would first suggest you to reset the switch; unplug it, wait a minute and plug it back in, then try the console connection through hyperterminal as described in the chapter 4 of the admin guide;
http://www.cisco.com/en/US/docs/switches/lan/csbms/srw2048/administration/guide/SRW-US_v10_UG_A-Web.pdf
If the problem persists reset the router once more and try the web-based utility as described by the same admin guide, chapter 5.
If you are still unable to login the device I would then suggest you to contact the Small Business Contact Center for further assistance and please do not hesitate to reach me back if there is anything I may assist you with in the meantime.
https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
