06-04-2013 06:25 AM
Hello Community,
I have a problem with configure of LAG on Cisco SFE2010P 3xSwitch stack.
The switch has actually only web GUI. Console - too, but it's not very helpful.
I need to configure Interfaces 1/g3 and 2/g3 in a LAG. And allow vlans 60 (default vlan) and 110 (voice) to be sent through.
After I configured the LAG with the two interfaces, the LAG "Port to Vlan" settings show me the vlan 60 is untagged and vlan 110 is tagged.
But if I take a look on the Interfaces 1/g3 and 2/g3 "Port to LAN" settings, the both vlans on the interfaces are "excluded". With this settings I cannot access the default gateway, which is directly connected. The default gateway is a 3750Stack with HSRP IP address. It has two uplinks in port channel to the SFE2010P.
I have a single 100Mbps Interface on the SFE2010P that connected to a trunk interface on the backbone. And it works in this manner. But using LWL LAG links does not work now.
Why are the vlans 60 and 110 are excluded on the interfaces in the LAG and how can I change it? Thank you.
Sergej
Solved! Go to Solution.
06-05-2013 07:28 PM
Hi Sergej, you cannot configure the individual port within a LAG to a vlan. When you join the vlan you must select the lag group, not the individual port.
-Tom
Please mark answered for helpful posts
06-05-2013 07:28 PM
-Tom
06-05-2013 11:46 PM
Hi Tom,
thank you for answer.
But I found yesterday, that my problem was the native vlan mismatsch on the link between SFE2010 and Cat3750. After I changed it on the Catalyst, the port channel and trunk link started to work.
But surely your answer was correct.
Kind regards,
Sergej
