VPN traffic gets routed to default gateway
ylafont
Can anyone explain and provide guidance one how to address why traffic that is supposed to be routed to a VPN address gets routed to the Default gateway?
Traceroute result from VLAN20 (local Machine IP 10.100.20.11)
C:\WINDOWS\system32>tracert 192.168.10.100
Tracing route to 192.168.10.100 over a maximum of 30 hopsvpn, traffi
1 1 ms 5 ms 5 ms 10.100.20.253vpn, traffi
2 1 ms <1 ms <1 ms 192.168.110.1  <-----------VPN Router
3 1 ms <1 ms <1 ms 192.168.101.1 <------------Default Gateway of local internet router
4 9 ms 9 ms 15 ms 10.19.184.1
5 * * * Request timed out.
6 ^C
From the switch (sg300)  I can ping across the vpn router without an issues.
SW1#ping 192.168.10.100
Pinging 192.168.10.100 with 18 bytes of data:
18 bytes from 192.168.10.100: icmp_seq=1. time=40 ms
18 bytes from 192.168.10.100: icmp_seq=2. time=20 ms
18 bytes from 192.168.10.100: icmp_seq=3. time=20 ms
18 bytes from 192.168.10.100: icmp_seq=4. time=20 ms
I have static route on the VPN router and it can ping the workstation on VALN20
I am attaching  current running config and a remedial network diagram.
guidance and assistance is greatly appreciated thank you in advance.
6 Replies 6
Deepak Kumar
This issue belongs to the VPN router configuration. As you the destination 192.168.10.x must be encrypted by the router and send over the VPN but it is not happening.  Your SG switch is doing his task correctly.
As per your tracert command output from the system, SG routing this traffic correctly and traffic heating to the VPN router as well.
Now check VPN router configuration and most properly issue belongs to the ACL (VPN interesed traffic ACL). Add your VLAN 20 subnet in that ACL.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Deepak,
Thank you for taking the time and effort and your guidance.
Would setting  the ACL still need to be preformed if the VPN is already active and PC's on that Network can communicate across it? PC on the 192.168.110.x can see and use resources from 192.168.10.0
also, that  VPN router router is not Cisco but rather a TP-Link (TL-600VPN). there is an access control section, but nothing that will allow the addition a of Cisco VLAN20 (which i have tried both enabled and disabled.)
Please share IPSEC-VPN page screenshot.
Deepak Kumar
Deepak Kumar,
IPsec policy consists of three sections
IKE  (VPN passphrase)
IpSec -  Connection information
SA List -  (list of active connections)
Thank you again.
VLAN 20 subnet is not added in the Local Subnet under the List of IPSec Policy. Please add VLAN 20 subnets in local subnet and at the remote site also add in the remote subnet.
Deepak Kumar
Deepak Kumar,
I tried this previously (i think), without success.  I may have the address incorrect  or i may be missing something else where.    Please let me know.
Excuse my ignorance, new to all this stuff. thank you again.
