ā02-20-2024 03:39 AM
HI THERE
I WANT TO CHECK WARRANTY OF MY CISCO SWITCH. CBS-350-48P-4G.
SERIAL NUMBER=PSZ264919G5
ā02-20-2024 03:47 AM
Go to https://cway.cisco.com/mydevices/devices then log in using the correct CCO login. Enter a valid serial number one by one or by bulk.
ā02-20-2024 03:52 AM
I VISITED THE SITE BUT THERE IS NO LOGIN OPTION .I DID NOT FIND ANY LOGIN PORTAL.
ā02-20-2024 04:17 AM
If you are currently logged in (for example using your CCO here) you will not be prompted to login.
ā02-20-2024 04:38 AM
There is some option eg, summary, devices, reports and activities. where I have to check warranty?
ā02-20-2024 05:17 AM - edited ā02-20-2024 05:18 AM
@Hamza malik hi use this https://cway.cisco.com/sncheck/
I can see its not covered under any contract
