whats happened with SLM224G
1Alukard1
Hello!
I'm sorry for my bad english, but I need your help...
One of the switches in the company where I work is broken down. As soon as I turn on it, its indicator named "system" is blinking non stop... And every 42 seconds all its indicators(24LAN and 2Uplink) blinking at one moment -- it's like rebooting every 42seconds... Switch don't respond!!!
If I press a reset button it's maybe reboot, but nothing happened... If I restaint reset button for 8/15 seconds it's dont respond for it action( perhaps it is restore its settings to default, but I can't verify it because switch isn't respond any ping or http request... ).
I want to know it is hopelessly or I can reanimate it???
I look forward to your advice. Thanks for all...
danilorcesar
I need firmware 2.0.0.10 or 1.0.X.
Can you make the firmware available?
