Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2810 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4353 Views
  • 1 replies
  • 16 Helpful votes
Hi,  Somebody help me to describe.  I'm used   SG550X-24 Stack unit  to core-switch   and  SG220-26P  to access switch  config LAG  mode auto on both switch.Sometimes  clients are disconnect from system 20 minutes.  Then I check log on both switch  f...
KJ.A by Level 1
  • 1070 Views
  • 3 replies
Hi, After having set Management ACL rules on my switch, I enabled the DNS resolution to properly poll sntp serversHowever, I noticed theses warnings, received on a regular interval:Warning %MNGINF-W-ACL: Management ACL drop packet received on interfa...
Filomena by Level 1
  • 1386 Views
  • 12 replies
Hi, My question to the product warranty period: Cisco warranty finder says: 90 day or 1 year. Info page says: "limited warranty" what is correct one? Product: SG 300 - 10 port and SG 300 - 28 port Switch. I did use: https://cway.cisco.com/sncheck...
siltal021 by Level 1
  • 6218 Views
  • 3 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
