Dear all,
sorry if this has been asked before but I can't find a solution using the search I'm trying to configure a SB300 and now I'm encountering a problem.
I've put the Switch into Layer 3 mode and created two additional VLANs, 2 & 3. Ports 1-8 and 10 are set to access mode and put into VLAN 3. Port 9 is a trunk with native VLAN 1 I'm connecting my PC to. I've kept the default IP 192.168.1.254 for VLAN1 and now I want to assign an IP to VLAN 2 and 3 so that I can access the switch when connected to one of these VLANs.
I now try the following commands to assign an IP address but as soon as I send them I always end not being able to communicate to the switch on the VLAN1 address.
conf t
interface vlan 2
ip address 172.16.0.23 /20
conf t
interface vlan 3
ip address 172.16.16.23 /20
Can anyone tell me why this works on the 2960's I've encountered until now but not on the SB 300? As I cannot connect using the serial console (for some reason I receive information but I cannot send even though it's the original cable and the interface on my PC works with other devices) this is a big issue for me.
Thanks for your help
Thomas
