Wrong mac address from stack SG500?
LoDo
It's my connection scheme.
There is a routing problem between vlans if one of the devices connected to the unit 2.
Within the same vlan devices are available for each other.
If PC200 connected to Gi1/1/15
Sniff ICMP traffic on Gi1/1/15:
Icmp request from 192.168.112.1 to 192.168.101.200:
Src: 24:01:c7:08:02:49 (192.168.101.254),
Dst: b8:88:e3:0e:1a:da (192.168.101.200)
  Icmp replly from 192.168.101.200 to 192.168.112.1:
Src: b8:88:e3:0e:1a:da (192.168.101.200)
Dst: 24:01:c7:08:02:49 (192.168.101.254)
If PC200 connected to Gi2/1/15
Sniff ICMP traffic on Gi2/1/15:
Src: 24:01:c7:08:00:01 (192.168.101.254),
Dst: 24:01:c7:08:00:01 (192.168.101.254)
Where does this mac-address (24:01:c7:08:00:01) appear? In the arp table on PC200 it is none.
Lodo, I believe this is a bug. Best I'd recommend is call the SBSC and make a case. I believe it is related to bug
CSCub82382
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
18 Replies 18
Tom Watts
Well, I'm guess you may be seeing a port MAC address.
Are you on the newest firmware?
-Tom
Firmware version 1.3.5.58.
This address (24:01:c7:08:00:01) it is not in the mac-address table.
swcore#sh mac address-table address 24:01:c7:08:00:01
Aging time is 300 sec
  Vlan        Mac Address         Port       Type
swcore#sh mac address-table address 24:01:c7:08:02:49
   1       24:01:c7:08:02:49       0         self
With firmware 1.3.0.62 the same problem.
If the interface Gi2/1/15 to down and up - the first two icmp request has a source MAC
24:01:c7:08:02:49, remaining request has a source MAC 24:01:c7:08:00:01.
#show stack
Unit Model Name     MAC Address       Software  Master   Unit No./       Status       Mode After Reboot
1    SG500-28       24:01:c7:08:02:49   1.3.0.62  Enabled         1,            master              Native
2    SG500-28       24:01:c7:08:02:2c   1.3.0.62  Enabled         2,            backup              Native
And I suspect from within the same VLAN the issue is not present. That would suggest the switch is incorrectly using the port MAC instead of the system MAC.
-Tom
Yes, within one vlan such problems aren't present. In this case, the source mac address - real mac address of the computer from which icmp requests are sent.
If to ping from the switch, source mac address is 24:01:c7:08:02:49.
The mac address 24:01:c7:08:00:01appears if the icmp request is routed on the switch. Such situation for any port of  the stack unit 2.
LoDo
Somebody has any ideas how to fix it?
CSCub82382
-Tom
I'm running into the same (or very similar) problem. The bug report Tom put up is locked. I'm going to give SBSC a ring, and see if they have a update.
TAC confirmed this bug. Fix will be in the next firmware version.
Today I received a beta version, but have not tested it yet.
All,
Firmware version 1.3.7.18 was released today.
- Marty
Yay :-)
Out of curiosity, is this the same as CSCub82382, or was that already fixed in a previous firmware? The bug report is restricted, so I can't see it myself.
danielj80,
CSCub82382: SG500 - device is malforming packets It appears that this was resolved in a previous firmware.
- Marty
Message was edited by: Martin Pyhala
Someone official may want to update
https://supportforums.cisco.com/thread/2141121 as it seems to be very similar, and this firmware may help some thread followers.
I just put the firmware on, but it didn't resolve my problem (MAC address announcements hopping between ports). I noticed the firmware release notes didn't claim to correct any defects. Is this bug corrected in today's firmware, or slated for a later one?
