Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 979 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5727 Views
  • 1 replies
  • 16 Helpful votes
May I know what is the differences between GLC-T and SFP-GE_T?What I found out through net are as follows :GLC-T1000BASE-T SFP RJ45 100m transceiverSpecificationsForm Factor: SFPDevice Type: Transceiver moduleConnectivity Technology: WiredWavelength:...
yezawkhant by Level 1
  • 15943 Views
  • 4 replies
Hello all,We recently bought a few Small Business switches. 1x SG500-52, 2x SF500-24P and 10x SG300-10P.All switches have the latest firmware installed and are set to Layer 3.On all switches we created VLAN's.Vlan Config :1    Default VLAN2    Voice_...
We have a SG200-26. This dumb switch is connected to a trunk port of the SG200. This dumb switch has a couple of other switches that connect to it. Another dumb another managed. I know dumb switches aren't good but that's what I have been given and h...
sammycbmi by Level 1
  • 846 Views
  • 1 replies
Hello-We have a SG300-10P as well as a SF302-08P. They are providing PoE and data for a mixture of 7961s, 7960s, SPA504s and SPA514s. The problem is that there is a very audible "hum" on the 79XX phones that are connected to the SG300.Moving the phon...
Resolved! SG200-26p - DHCP
Hi all, I just want to confirm something.Can the above switch be a DHCP server?Im limited on Virtual resource and cannot create another VM (at the moment) to be a DHCP server, this is in our testing lab so I cannot add a dhcp server to any of the cur...
Hi, I hope someone can help me, I have several SG500-48 switches, recently on 2 of these devices the connection is wobbly.  I have inter changed the power cable but no change. Also I moved the switches into a different environment but no change.Pleas...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
