12-14-2018 07:33 AM
How can I connect my main switch 2960X (connected to Windows server and router for dhcp) to the second switch Cisco SG350 to expend my network? I tried it with a straight and a cross over ethernet network cat 6 cabel. The leds flashes just 3 seconds and than my port on the 2960X is marked red in my configuration web interface.
Any idea? Do I have to change something in the setting of the port or in the switch?
Solved! Go to Solution.
12-15-2018 07:36 AM
Solved by myself just setting the ports to access on both switches and disable spanning tree on the sg350. That’s all and it works;)
12-14-2018 09:27 AM
You need to configure Trunk configuration between 2960 and SG350.
Or post the configuration of both and tell us what port you are connection each other.
12-15-2018 07:36 AM
