Bookmark
Subscribe
2028
1/10/25G Gigabit Ethernet
yong khang NG
Level 5
Level 5
Hi all
would like to checkout if the datasheet with this statement
Does it mean the switchport setting can mix and match of 10G and 25G SFP, working simultaneously?
For the switch can only working in one mode all time - choice either 10G, or 25G?
Noel
Leo Laohoo
It means the optical port can support 1-, 10- or 25 Gbps optical modules.
The "gotcha" to all of this will be the supported optical "models" or SKU.
Usually, SR (short reach) is first supported during hardware release and other wavelengths will be "added" in future software releases.
balaji.bandi
mGig ports work at different speeds.
BB
Yup, although copper Ethernet.
