11-15-2006 03:10 AM - edited 03-05-2019 12:49 PM
Does anyone know what "throttles" mean on 10 interface stats. Is it a issue, whats causing this.
Thanks.
TenGigabitEthernet1/1 is up, line protocol is up (connected)
Hardware is C6k 10000Mb 802.3, address is 0015.c746.4800 (bia 0015.c746.4800)
Description: 10g Connection to LN-BSQ-0A-CER1-DDIST-1A
Internet address is 172.28.1.170/30
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Carrier delay is 0 msec
Full-duplex, 10Gb/s
input flow-control is desired, output flow-control is on
ARP type: ARPA, ARP Timeout 00:25:00
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 1w1d
Input queue: 0/75/0/24633 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 123000 bits/sec, 182 packets/sec
30 second output rate 2702000 bits/sec, 322 packets/sec
L2 Switched: ucast: 4610837 pkt, 413638781 bytes - mcast: 763160 pkt, 90053981 bytes
L3 in Switched: ucast: 28297584 pkt, 12157030270 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 34006365 pkt, 27458288081 bytes mcast: 0 pkt, 0 bytes
34055244 packets input, 12692520423 bytes, 0 no buffer
Received 1145429 broadcasts (763120 IP multicast)
0 runts, 0 giants, 4967 throttles
0 watchdog, 0 multicast, 0 pause input
39597225 packets output, 28007200104 bytes, 0 underruns
11-15-2006 03:43 AM
Throttles usually occurs when the interfaces input hold queue is full.
Probably packets are comming faster than interface can process them...
Check the nature of this. If it is simply short time bursts you can simply increase lenght of the input queue...
//Mikhail Galiulin
