OSPF Routes
thestagman
I'm having a bit of mare advertising some routes from one 3750 L3 Switch to another 3750 using OSPF.
Both routers below are linked together via 6 foot Cat 6 cable. This interswitch connectivity uses 802.1q trunking. Local routing is fine.
Router 1
network 10.251.10.0 0.0.0.255 area 0
network 10.251.20.0.0.0.0.255 area 0
network 10.250.1.0 0.0.0.3 area 0
Router 2
Remote router A
network 10.250.10.0 0.0.0.255 area 0
network 10.250.20.0 0.0.0.255 area 0
Router 1 learns of the routes from Router A. But these remote routes are not passed onto Router 2.
I have performed a Clear IP route * as well as a clear ip ospf process
both sites use OSPF process No 1 and all networks are in Area 0
Does any one have any advice ?
icabrera
Level 4
Level 4
Have you use any debug command?, Try to use "debug ip ospf" and clear the ospf process again to see what is happening with the debug active.
spremkumar
Level 9
Level 9
Can you post the config of all the routers here with the interface level configs included?
also can you post out the output of show ip ospf neighbor taken from all the routers ?
regds
Its okay, I have just seen the error of my ways and it was so obvious I'm embarrassed to say what it was...
Thanks to those who helped me..
Goes away all red faced....
glen.grant
Make sure none of your connecting interfaces are "passive" . I believe passive interface is on by default and you have to "no passive" the interface or the layer 3 SVI for the interfaces you want to pass routes . It should tell you using "show ip ospf interface " command . I guess my other question would be if you are trunking between them why do you need to route , all your networks are available across that trunk .
