04-27-2014 12:42 AM - edited 03-07-2019 07:14 PM
Is it possible to connect a 10 GIG SFP module(multimode) in the below 4503 switch. Is it compatible with the below switch...
cisco WS-C4503-E (MPC8245) processor (revision 4) with 262144K bytes of memory.
Processor board ID SPE120700HU
MPC8245 CPU at 267Mhz, Supervisor II+TS
Last reset from Reload
7 Virtual Ethernet interfaces
20 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
NAME: "Switch System", DESCR: "Cisco Systems, Inc. WS-C4503-E 3 slot switch "
PID: WS-C4503-E , VID: V01, SN: SPE120700HU
NAME: "Linecard(slot 1)", DESCR: "Supervisor II+TS with 12 10/100/1000BaseT RJ45
V voice powerports, and 8 1000Bas"
PID: WS-X4013+TS , VID: V07, SN: JAE1111950X
NAME: "GigabitEthernet1/13", DESCR: "1000BaseSX"
PID: SFBR-5766PZ , VID: , SN: AGM12091C60
NAME: "GigabitEthernet1/14", DESCR: "1000BaseSX"
PID: QFBR-5766LP , VID: , SN: AGS094756P6
NAME: "GigabitEthernet1/15", DESCR: "1000BaseT"
PID: ABCU-5710RZ-CS2 , VID: , SN: AGM121220LX
NAME: "GigabitEthernet1/17", DESCR: "1000BaseT"
PID: SP7041_Rev_F , VID: F , SN: 00000MTC15200CMT
NAME: "GigabitEthernet1/19", DESCR: "1000BaseSX"
PID: FTRJ8519P1BNL , VID: A , SN: FNS104WD2P4
NAME: "GigabitEthernet1/20", DESCR: "1000BaseSX"
PID: SFBR-5766PZ-CS1 , VID: , SN: AGM142314TE
NAME: "Fan", DESCR: "FanTray"
PID: WS-X4593-E , VID: V01, SN: SPE120700CM
NAME: "Power Supply 1", DESCR: "Power Supply ( AC 1300W )"
PID: PWR-C45-1300ACV , VID: , SN: SNI0849AR7B
NAME: "Power Supply 2", DESCR: "Power Supply ( AC 1300W )"
PID: PWR-C45-1300ACV , VID: V04, SN: SNI1046ARA2
Thanks & Regards,
M.Mohamed Raffiudeen...
04-27-2014 01:54 AM
I think 10G is not supported. You should advice the product page as well.
04-27-2014 06:06 AM
Do we need to upgrade this switch?
Pls let me know what should we do to install 10 gig module...
04-27-2014 06:50 AM
Please provide the show module command output.
04-27-2014 06:58 AM
Pls find the output...
WS_AJVA_4503_CORE#sh module
Chassis Type : WS-C4503-E
Power consumed by backplane : 0 Watts
Mod Ports Card Type Model Serial No.
1 20 Sup II+TS 10/100/1000BaseT (RJ45), SFP WS-X4013+TS JAE1111950X
M MAC addresses Hw Fw Sw Status
1 001f.6cd1.eac0 to 001f.6cd1.ead3 1.7 12.2(20r)EW1 12.2(44)SG Ok
WS_AJVA_4503_CORE#
04-27-2014 07:53 AM
If I am not wrong you have a left module on the chassis, is that right? So you have install a module that supports 10G interfaces? I think for 4500 series there is one line card supporting 6 (or 12) TenG interfaces.
06-26-2014 05:06 AM
Tnx for your time.
10G line card is not supported and we have been tool to upgrade to 4506 E.
Thanks & Regards...
04-27-2014 09:31 PM
Why would you want to do that? the 4503-E chassis can't support more than 6 Gbps per slot.
You may want to upgrade to a 4500R+E chassis and get a bundle (which includes the supervisor card).
