06-22-2017 06:52 AM - edited 03-08-2019 11:04 AM
Can you put 100Gbs fiber interfaces into a port-channel on a Nexus 7k switch?
I was going to use the 100Gbs interfaces I have for the vpc peer-link, but I wasn't sure if there were limitations on putting these types of interfaces into a port-channel.
Solved! Go to Solution.
06-25-2017 03:49 PM
06-25-2017 03:49 PM
yes you can bundle the 100gb ports for the peer-link
