100mbps speed in 3850 XS interface
Debbie Tru
Hey guys!
I need your kind support, we have a device (camera) with an interface FastEthernet. the conections is like this:
Camera->Media Converter->Single Mode Fiber->(Gbic 1000) GLC-LH-SM-> Cisco 3850 XS interface
But to try change the speed in interface its denied.
Any sugesstions?
7 Replies 7
Which interface are you using ? Post the output of 'show interface' of the interface where you are trying to change the speed...
Predrag Jovic
Level 3
Level 3
On newer devices for SFP ports there is no speed command for manually configuring interface speed (except speed nonegotiate). 100Mb speed is not supported on SFP ports on 3850 XS - except for module GLC-GE-100FX.
Reza Sharifi
You optic is a gig optic (Gbic 1000) GLC-LH-SM) and can't be change to 100Mb. If you want to use it as 100Mb, than you need to change your optic.
hth
We have an connectivity issue with cisco 3850 fibers switch  with sfp and 100mbps fiber camera sfp.
One end we are using  WS-C3850-48xs with sfp GLC-GE-DR-LX and other end we have siqura fiber camera with 100 mbps sfp.we cant able to establish connection. Kindly support
thats not a supported SFP GLC-GE-DR-LX on a 3850XS , use a supported SFPfr im list below , or check tmgmatrix online
C3850
Transceiver Description Software Release
Network Device Product ID Transceiver Product ID Data Rate Form Factor Reach Cable Type Media Connector Type Transceiver Type Case Temp DOM HW Capable Minimum DOM SW
WS-C3850-48XS GLC-GE-100FX 100 Mbps SFP 2km Duplex Fiber MMF LC Optic 0 to 70C N IOS XE 16.3.3 —
SFP-10G-SR 10 Gbps SFP+ 300m (OM3) Duplex Fiber MMF LC Optic 0 to 70C Y IOS XE 3.7.2 IOS XE 3.7.2
SFP-10G-SR 10 Gbps SFP+ 400m (OM4) Duplex Fiber MMF LC Optic 0 to 70C Y IOS XE 3.7.2 IOS XE 3.7.2
SFP-10G-SR 10 Gbps SFP+ 300m (OM3) Duplex Fiber MMF LC Optic 0 to 70C Y IOS 16.2.1 IOS 16.2.1
SFP-10G-SR 10 Gbps SFP+ 400m (OM4) Duplex Fiber MMF LC Optic 0 to 70C Y IOS 16.2.1 IOS 16.2.1
SFP-10G-SR-S 10 Gbps SFP+ 300m (OM3) Duplex Fiber MMF LC Optic 0 to 70C Y IOS XE 3.7.2 IOS XE 3.7.2
SFP-10G-SR-S 10 Gbps SFP+ 400m (OM4) Duplex Fiber MMF LC Optic 0 to 70C Y IOS XE 3.7.2 IOS XE 3.7.2
SFP-10G-SR-S 10 Gbps SFP+ 300m (OM3) Duplex Fiber MMF LC Optic 0 to 70C Y IOS 16.2.1 IOS 16.2.1
SFP-10G-SR-S 10 Gbps SFP+ 400m (OM4) Duplex Fiber MMF LC Optic 0 to 70C Y IOS 16.2.1 IOS 16.2.1
SFP-10G-SR-X 10 Gbps SFP+ 300m (OM3) Duplex Fiber MMF LC Optic -5 to 85C Y IOS 16.10.1 IOS 16.10.1
SFP-10G-LRM 10 Gbps SFP+ 220m Duplex Fiber MMF LC Optic 0 to 70C Y IOS XE 3.7.2 IOS XE 3.7.2
SFP-10G-LRM 10 Gbps SFP+ 300m Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 3.7.2 IOS XE 3.7.2
SFP-10G-LRM 10 Gbps SFP+ 220m Duplex Fiber MMF LC Optic 0 to 70C Y IOS 16.2.1 IOS 16.2.1
SFP-10G-LRM 10 Gbps SFP+ 300m Duplex Fiber SMF LC Optic 0 to 70C Y IOS 16.2.1 IOS 16.2.1
SFP-10G-LR 10 Gbps SFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 3.7.2 IOS XE 3.7.2
SFP-10G-LR 10 Gbps SFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y IOS 16.2.1 IOS 16.2.1
SFP-10G-LR-S 10 Gbps SFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 3.7.2 IOS XE 3.7.2
SFP-10G-LR-S 10 Gbps SFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y IOS 16.2.1 IOS 16.2.1
SFP-10G-LR-X 10 Gbps SFP+ 10km Duplex Fiber SMF LC Optic -5 to 85C Y IOS 16.10.1 IOS 16.10.1
SFP-10G-ER 10 Gbps SFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 3.7.2 IOS XE 3.7.2
SFP-10G-ER 10 Gbps SFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y IOS 16.2.1 IOS 16.2.1
SFP-10G-ER-S 10 Gbps SFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 3.7.2 IOS XE 3.7.2
SFP-10G-ER-S 10 Gbps SFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y IOS 16.2.1 IOS 16.2.1
SFP-10G-ZR 10 Gbps SFP+ 80km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 3.7.2 IOS XE 3.7.2
SFP-10G-ZR 10 Gbps SFP+ 80km Duplex Fiber SMF LC Optic 0 to 70C Y IOS 16.2.1 IOS 16.2.1
SFP-10G-ZR-S 10 Gbps SFP+ 80km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 3.7.2 IOS XE 3.7.2
SFP-10G-ZR-S 10 Gbps SFP+ 80km Duplex Fiber SMF LC Optic 0 to 70C Y IOS 16.2.1 IOS 16.2.1
SFP-10G-BXD-I 10 Gbps SFP+ 10km Single-strand SMF LC Optic -40 to 85C Y IOS XE 3.7.2 IOS XE 3.7.2
SFP-10G-BXD-I 10 Gbps SFP+ 10km Single-strand SMF LC Optic -40 to 85C Y IOS 16.2.1 IOS 16.2.1
SFP-10G-BXU-I 10 Gbps SFP+ 10km Single-strand SMF LC Optic -40 to 85C Y IOS XE 3.7.2 IOS XE 3.7.2
SFP-10G-BXU-I 10 Gbps SFP+ 10km Single-strand SMF LC Optic -40 to 85C Y IOS 16.2.1 IOS 16.2.1
SFP-10G-BX40D-I 10 Gbps SFP+ 40km Single-strand SMF LC Optic -40 to 85C Y IOS XE 3.7.2 IOS XE 3.7.2
SFP-10G-BX40D-I 10 Gbps SFP+ 40km Single-strand SMF LC Optic -40 to 85C Y IOS 16.2.1 IOS 16.2.1
SFP-10G-BX40U-I 10 Gbps SFP+ 40km Single-strand SMF LC Optic -40 to 85C Y IOS XE 3.7.2 IOS XE 3.7.2
SFP-10G-BX40U-I 10 Gbps SFP+ 40km Single-strand SMF LC Optic -40 to 85C Y IOS 16.2.1 IOS 16.2.1
SFP-H10GB-CU1M 10 Gbps SFP+ 1m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 3.7.2 —
SFP-H10GB-CU1M 10 Gbps SFP+ 1m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS 16.2.1 —
SFP-H10GB-CU3M 10 Gbps SFP+ 3m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 3.7.2 —
SFP-H10GB-CU3M 10 Gbps SFP+ 3m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS 16.2.1 —
SFP-H10GB-CU5M 10 Gbps SFP+ 5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 3.7.2 —
SFP-H10GB-CU5M 10 Gbps SFP+ 5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS 16.2.1 —
SFP-H10GB-ACU7M 10 Gbps SFP+ 7m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 3.7.2 —
SFP-H10GB-ACU7M 10 Gbps SFP+ 7m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS 16.2.1 —
SFP-H10GB-ACU10M 10 Gbps SFP+ 10m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 3.7.2 —
SFP-H10GB-ACU10M 10 Gbps SFP+ 10m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS 16.2.1 —
SFP-10G-AOC1M 10 Gbps SFP+ 1m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 3.7.2 —
SFP-10G-AOC1M 10 Gbps SFP+ 1m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS 16.2.1 —
SFP-10G-AOC2M 10 Gbps SFP+ 2m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 3.7.2 —
SFP-10G-AOC2M 10 Gbps SFP+ 2m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS 16.2.1 —
SFP-10G-AOC3M 10 Gbps SFP+ 3m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 3.7.2 —
SFP-10G-AOC3M 10 Gbps SFP+ 3m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS 16.2.1 —
SFP-10G-AOC5M 10 Gbps SFP+ 5m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 3.7.2 —
SFP-10G-AOC5M 10 Gbps SFP+ 5m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS 16.2.1 —
SFP-10G-AOC7M 10 Gbps SFP+ 7m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 3.7.2 —
SFP-10G-AOC7M 10 Gbps SFP+ 7m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS 16.2.1 —
SFP-10G-AOC10M 10 Gbps SFP+ 10m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 3.7.2 —
SFP-10G-AOC10M 10 Gbps SFP+ 10m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS 16.2.1 —
DWDM-SFP10G-XX.XX 10 Gbps SFP+ 80km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 3.7.2 IOS XE 3.7.2
DWDM-SFP10G-XX.XX 10 Gbps SFP+ 80km Duplex Fiber SMF LC Optic 0 to 70C Y IOS 16.2.1 IOS 16.2.1
CWDM-SFP10G-XXXX 10 Gbps SFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 3.7.2 IOS XE 3.7.2
CWDM-SFP10G-XXXX 10 Gbps SFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y IOS 16.2.1 IOS 16.2.1
GLC-T
End Of Sale
10/100/1000 Mbps SFP 100m Cat5e/6A Copper RJ-45 Optic 0 to 70C N IOS XE 3.7.2E —
GLC-T
End Of Sale
10/100/1000 Mbps SFP 100m Cat5e/6A Copper RJ-45 Optic 0 to 70C N IOS XE 16.2.1 —
GLC-TE 10/100/1000 Mbps SFP 100m Cat5e/6A Copper RJ-45 Optic -5 to 85C N IOS XE 3.7.5E —
GLC-TE 10/100/1000 Mbps SFP 100m Cat5e/6A Copper RJ-45 Optic -5 to 85C N IOS XE 16.3.5 —
GLC-BX-D 1 Gbps SFP 10km Single-strand SMF LC Optic 0 to 70C Y IOS XE 3.7.2E IOS XE 3.7.2E
GLC-BX-D 1 Gbps SFP 10km Single-strand SMF LC Optic 0 to 70C Y IOS XE 16.2.1 IOS XE 16.2.1
GLC-BX-U 1 Gbps SFP 10km Single-strand SMF LC Optic 0 to 70C Y IOS XE 3.7.2E IOS XE 3.7.2E
GLC-BX-U 1 Gbps SFP 10km Single-strand SMF LC Optic 0 to 70C Y IOS XE 16.2.1 IOS XE 16.2.1
QSFP-40G-SR4 40 Gbps QSFP+ 100m (OM3) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y IOS XE 16.2.2 IOS XE 16.2.2
QSFP-40G-SR4 40 Gbps QSFP+ 150m (OM4) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y IOS XE 16.2.2 IOS XE 16.2.2
QSFP-40G-SR4 40 Gbps QSFP+ 100m (OM3) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y IOS XE 3.7.2 IOS XE 3.7.2
QSFP-40G-SR4 40 Gbps QSFP+ 150m (OM4) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y IOS XE 3.7.2 IOS XE 3.7.2
QSFP-40G-CSR4 40 Gbps QSFP+ 300m (OM3) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y IOS XE 16.2.2 IOS XE 16.2.2
QSFP-40G-CSR4 40 Gbps QSFP+ 400m (OM4) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y IOS XE 16.2.2 IOS XE 16.2.2
QSFP-40G-CSR4 40 Gbps QSFP+ 300m (OM3) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y IOS XE 3.7.2 IOS XE 3.7.2
QSFP-40G-CSR4 40 Gbps QSFP+ 400m (OM4) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y IOS XE 3.7.2 IOS XE 3.7.2
QSFP-40G-SR4-S 40 Gbps QSFP+ 100m (OM3) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y IOS XE 16.2.2 IOS XE 16.2.2
QSFP-40G-SR4-S 40 Gbps QSFP+ 150m (OM4) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y IOS XE 16.2.2 IOS XE 16.2.2
QSFP-40G-SR4-S 40 Gbps QSFP+ 100m (OM3) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y IOS XE 3.7.2 IOS XE 3.7.2
QSFP-40G-SR4-S 40 Gbps QSFP+ 150m (OM4) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y IOS XE 3.7.2 IOS XE 3.7.2
QSFP-40G-SR-BD 40 Gbps QSFP+ 100m (OM3) Duplex Fiber MMF LC Optic 10 to 70C N IOS XE 16.2.1 —
QSFP-40G-SR-BD 40 Gbps QSFP+ 150m (OM4) Duplex Fiber MMF LC Optic 10 to 70C N IOS XE 16.2.1 —
QSFP-40G-SR-BD 40 Gbps QSFP+ 100m (OM3) Duplex Fiber MMF LC Optic 10 to 70C N IOS XE 3.7.2 —
QSFP-40G-SR-BD 40 Gbps QSFP+ 150m (OM4) Duplex Fiber MMF LC Optic 10 to 70C N IOS XE 3.7.2 —
QSFP-40G-LR4-S 40 Gbps QSFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.2.2 IOS XE 16.2.2
QSFP-40G-LR4-S 40 Gbps QSFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 3.7.2 IOS XE 3.7.2
QSFP-40G-LR4-S 40 Gbps QSFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.3.3 —
QSFP-40G-LR4-S 40 Gbps QSFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.5.1a —
QSFP-40G-LR4 40 Gbps QSFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.2.2 IOS XE 16.2.2
QSFP-40G-LR4 40 Gbps QSFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 3.7.2 IOS XE 3.7.2
QSFP-40G-ER4 40 Gbps QSFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.2.2 IOS XE 16.2.2
QSFP-40G-ER4 40 Gbps QSFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.3.3 —
WSP-Q40GLR4L 40 Gbps QSFP+ 2km Duplex Fiber SMF LC Optic 10 to 60C Y IOS XE 16.2.2 IOS XE 16.2.2
WSP-Q40GLR4L 40 Gbps QSFP+ 2km Duplex Fiber SMF LC Optic 10 to 60C Y IOS XE 16.5.1a —
QSFP-4SFP10G-CU5M 40 Gbps QSFP+ 5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.2.2 —
QSFP-4SFP10G-CU3M 40 Gbps QSFP+ 3m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.2.2 —
QSFP-4SFP10G-CU1M 40 Gbps QSFP+ 1m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.2.2 —
QSFP-4X10G-AC7M 40 Gbps QSFP+ 7m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.2.2 —
QSFP-4X10G-AC10M 40 Gbps QSFP+ 10m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.2.2 —
QSFP-H40G-CU5M 40 Gbps QSFP+ 5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.2.2 —
QSFP-H40G-CU5M 40 Gbps QSFP+ 5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 3.7.2 —
QSFP-H40G-CU3M 40 Gbps QSFP+ 3m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.2.2 —
QSFP-H40G-CU3M 40 Gbps QSFP+ 3m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 3.7.2 —
QSFP-H40G-CU1M 40 Gbps QSFP+ 1m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.2.2 —
QSFP-H40G-CU1M 40 Gbps QSFP+ 1m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 3.7.2 —
QSFP-H40G-ACU7M 40 Gbps QSFP+ 7m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.2.1 —
QSFP-H40G-ACU7M 40 Gbps QSFP+ 7m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 3.7.2 —
QSFP-H40G-ACU10M 40 Gbps QSFP+ 10m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.2.2 —
QSFP-H40G-ACU10M 40 Gbps QSFP+ 10m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 3.7.2 —
QSFP-4X10G-AOC1M 40 Gbps QSFP+ 1m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.2.2 —
QSFP-4X10G-AOC2M 40 Gbps QSFP+ 2m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.2.2 —
QSFP-4X10G-AOC3M 40 Gbps QSFP+ 3m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.2.2 —
QSFP-4X10G-AOC5M 40 Gbps QSFP+ 5m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.2.2 —
QSFP-4X10G-AOC7M 40 Gbps QSFP+ 7m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.2.2 —
QSFP-4X10G-AOC10M 40 Gbps QSFP+ 10m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.2.2 —
GLC-BX40-D-I 1 Gbps SFP 40km Single-strand SMF LC Optic -40 to 85C Y IOS XE 3.7.2E IOS XE 3.7.2E
GLC-BX40-D-I 1 Gbps SFP 40km Single-strand SMF LC Optic -40 to 85C Y IOS XE 16.2.1 IOS XE 16.2.1
GLC-BX40-U-I 1 Gbps SFP 40km Single-strand SMF LC Optic -40 to 85C Y IOS XE 3.7.2E IOS XE 3.7.2E
GLC-BX40-U-I 1 Gbps SFP 40km Single-strand SMF LC Optic -40 to 85C Y IOS XE 16.2.1 IOS XE 16.2.1
GLC-BX80-D-I 1 Gbps SFP 80km Single-strand SMF LC Optic -40 to 85C Y IOS XE 3.7.2E IOS XE 3.7.2E
GLC-BX80-D-I 1 Gbps SFP 80km Single-strand SMF LC Optic -40 to 85C Y IOS XE 16.2.1 IOS XE 16.2.1
GLC-BX80-U-I 1 Gbps SFP 80km Single-strand SMF LC Optic -40 to 85C Y IOS XE 3.7.2E IOS XE 3.7.2E
GLC-BX80-U-I 1 Gbps SFP 80km Single-strand SMF LC Optic -40 to 85C Y IOS XE 16.2.1 IOS XE 16.2.1
GLC-BX40-DA-I 1 Gbps SFP 40km Single-strand SMF LC Optic -40 to 85C Y IOS XE 3.7.2E IOS XE 3.7.2E
GLC-BX40-DA-I 1 Gbps SFP 40km Single-strand SMF LC Optic -40 to 85C Y IOS XE 16.2.1 IOS XE 16.2.1
GLC-EX-SMD 1 Gbps SFP 40km Duplex Fiber SMF LC Optic -5 to 85C Y IOS XE 3.7.2E IOS XE 3.7.2E
GLC-EX-SMD 1 Gbps SFP 40km Duplex Fiber SMF LC Optic -5 to 85C Y IOS XE 16.2.1 IOS XE 16.2.1
SFP-GE-Z
End Of Sale
1 Gbps SFP 70km Duplex Fiber SMF LC Optic -5 to 85C Y IOS XE 3.7.2E IOS XE 3.7.2E
SFP-GE-Z
End Of Sale
1 Gbps SFP 70km Duplex Fiber SMF LC Optic -5 to 85C Y IOS XE 16.2.1 IOS XE 16.2.1
SFP-GE-T
End Of Sale
10/100/1000 Mbps SFP 100m Cat5e/6A Copper RJ-45 Optic -5 to 85C N IOS XE 3.7.2E —
SFP-GE-T
End Of Sale
10/100/1000 Mbps SFP 100m Cat5e/6A Copper RJ-45 Optic -5 to 85C N IOS XE 16.2.1 —
GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 3.7.2E IOS XE 3.7.2E
GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 16.2.1 IOS XE 16.2.1
GLC-LH-SMD 1 Gbps SFP 550m Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 3.7.2E IOS XE 3.7.2E
GLC-LH-SMD 1 Gbps SFP 10km Duplex Fiber SMF LC Optic -5 to 85C Y IOS XE 3.7.2E IOS XE 3.7.2E
GLC-LH-SMD 1 Gbps SFP 550m Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 16.2.1 IOS XE 16.2.1
GLC-LH-SMD 1 Gbps SFP 10km Duplex Fiber SMF LC Optic -5 to 85C Y IOS XE 16.2.1 IOS XE 16.2.1
GLC-ZX-SMD 1 Gbps SFP 70km Duplex Fiber SMF LC Optic -5 to 85C Y IOS XE 3.7.2E IOS XE 3.7.2E
CWDM-SFP-XXXX 1 Gbps SFP 100km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 3.7.2E IOS XE 3.7.2E
CWDM-SFP-XXXX 1 Gbps SFP 100km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.2.1 IOS XE 16.2.1
DWDM-SFP-XXXX 1 Gbps SFP 80km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 3.7.2E IOS XE 3.7.2E
DWDM-SFP-XXXX 1 Gbps SFP 80km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.2.1 IOS XE 16.2.1
SFP-H10GB-CU1-5M 10 Gbps SFP+ 1.5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 3.7.2 —
SFP-H10GB-CU2M 10 Gbps SFP+ 2m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 3.7.2 —
SFP-H10GB-CU2M 10 Gbps SFP+ 2m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS 16.2.1 —
SFP-H10GB-CU2-5M 10 Gbps SFP+ 2.5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 3.7.2 —
as per above list only available 100 mbps speed sfp in multimode fiber.but we are using single mode fiber.
is there any supported  100mbps sfp available in single mode or we have sfp GLC-LH-SMD it will support or we can reduce the speed?
connection detail: siqura outdoor camera with 100mbps builtin sfp----}single mode fo cable--}cisco ws-c3850-48xs-e with GLC-LH-SMD sfp
please help
You cant change the speed on fibre cable only copper , you need to change the SFP or the fibre type , single mode is for very long distance usually 500mtr up to 40km and can be much more expensive sfps , thats why there 1gb and 10gb , there is no 100mb single mode for that switch
