10G base-t
For the 10G base-T ports in the switches like WS-C3850-12X48U-S can this ports work as 1G 10/100/1000 and it will need specific cable or not ?
Reza Sharifi
The ports work as 100/1000 and 10G.  You can use cat 5e cat6 or cat 6a.  Cat 6a can do 10G up to 100 meters. Cat 6 and 5e can do 10G but for shorter distance (usually less than 50 meters).
Hi All,
I want to ask, so all 12 Port can be 10G Base T Copper and Can I connect all 12 Port 10G to Server with connector 10G Base T also.
Can you reference the documentation link for configure 10G and multigigabit because I cannot find the link
And For 36 Port in 3850 only support 10/100/1000 , Am I right ?
thanks,
Charis
