Bookmark
Subscribe
1464
NTP is not working - Cisco router
secureIT
Level 4
Level 4
Hi All,
We have a cisco router which is running with version 15-5-1-T2.bin
The problem is that My router is not syncing with NTP server
Config :-
ntp logging
ntp source GigabitEthernet0/1
ntp server 172.16.9.13
interface GigabitEthernet0/1
 ip address 172.16.12.14 255.255.255.248
 no ip redirects
 no ip proxy-arp
 ip accounting access-violations
 ip flow ingress
 ip policy route-map MYMAP1
 duplex full
 speed 1000
 no cdp enable
Logs :-
NTP message sent to 172.16.9.13, from interface 'GigabitEthernet0/1' (172.16.12.4).
 NTP message received from 172.16.9.13 on interface 'GigabitEthernet0/1' (172.16.12.4).
 NTP Core(DEBUG): ntp_receive: message received
 NTP Core(DEBUG): ntp_receive: peer is 0x148650E0, next action is 1.
#sh ntp associations
  address         ref clock       st   when   poll reach  delay  offset   disp
~172.16.9.13     .LOCL.           1     13     64    35  0.773 -18264. 16.434
* sys.peer, # selected, + candidate, - outlyer, x falseticker, ~ configured
devils_advocate
Level 7
Level 7
Can you point the router at a public NTP server to see if that syncs?
Okay, i had tried it but no luck. Can you gimme some valid pub ntp ip addresses pls.
http://www.pool.ntp.org/en/use.html
server 0.pool.ntp.org
server 1.pool.ntp.org
server 2.pool.ntp.org
server 3.pool.ntp.org
Will try and get back to you.
