10g ethernet module for catalyst 6500
dionisisz
Hello.
I have the following transceiver, HP B-series 10Gb SFP+ Short Range Transceiver
http://h30094.www3.hp.com/product/sku/10360906/mfg_partno/QK726A
I would like to know if there is any 10g ethernet module for catalyst 6500 which supports this connection.
Amit Singh
We have some newer 6900 line cards support SFP+ optics on 6500. They are support with SUP2T.
What is the 6500 system configuration for you?
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/data_sheet_c78-696623.html
You can use SFP+ optics on HP chassis and use normal X2 10G optics on 6500 modules. That should work fine.
Hope this helps.
-amit singh
I have 2 WS-SUP720-3B which does not support 10ge.
I'm thinking to replace these two supervisors with VS-720-10G-3C and buy 2 6708-10G modules with X2 adapters.
Is this configuration right?
Yes, that seems ok to me. I would suggest to look at 6716 module though which will allow you greater density though for future. You should be able to have this config work with SFP+ optics on HP chassis.
Just to make you doubly sure on this :
https://supportforums.cisco.com/thread/2179361
Hope this helps.
