some commands not accepted on asa 8.2 !!!!
Dr.X
Level 2
Level 2
hi all
i cant apply these commands on asa 8.2 ios :
object network RDP-REDIRECT
 nat (inside,outside) static interface service tcp 3389 3389
object network HTTP-REDIRECT
 nat (any,outside) static interface service tcp www www
object network HTTPS-REDIRECT
 nat (any,outside) static interface service tcp https https
object network CITRIX-ICA-HDX-REDIRECTION
 nat (inside,outside) static interface service tcp citrix-ica citrix-ica
object network CITRIX-ICA-SESSION-RELIABILITY-REDIRECTION
 nat (any,outside) static interface service tcp 2598 2598
object network MY-insideNET
        subnet 10.10.10.0 255.255.255.0
      nat (any,outside) after-auto 1 source dynamic MY-insideNET interface
ASAAAAA# sh version
Cisco Adaptive Security Appliance Software Version 8.2(5)
Device Manager Version 6.4(5)
Compiled on Fri 20-May-11 16:00 by builders
System image file is "disk0:/asa825-k8.bin"
Config file at boot was "startup-config"
ASAAAAA up 11 hours 11 mins
Hardware:   ASA5505, 512 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash Firmware Hub @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
                             Boot microcode   : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.05
0: Int: Internal-Data0/0    : address is d48c.b597.ce35, irq 11
1: Ext: Ethernet0/0         : address is d48c.b597.ce2d, irq 255
2: Ext: Ethernet0/1         : address is d48c.b597.ce2e, irq 255
3: Ext: Ethernet0/2         : address is d48c.b597.ce2f, irq 255
4: Ext: Ethernet0/3         : address is d48c.b597.ce30, irq 255
5: Ext: Ethernet0/4         : address is d48c.b597.ce31, irq 255
6: Ext: Ethernet0/5         : address is d48c.b597.ce32, irq 255
7: Ext: Ethernet0/6         : address is d48c.b597.ce33, irq 255
8: Ext: Ethernet0/7         : address is d48c.b597.ce34, irq 255
9: Int: Internal-Data0/1    : address is 0000.0003.0002, irq 255
10: Int: Not used            : irq 255
11: Int: Not used            : irq 255
Licensed features for this platform:
Maximum Physical Interfaces    : 8
VLANs                          : 3, DMZ Restricted
Inside Hosts                   : 50
Failover                       : Disabled
VPN-DES                        : Enabled
VPN-3DES-AES                   : Enabled
SSL VPN Peers                  : 2
Total VPN Peers                : 10
Dual ISPs                      : Disabled
VLAN Trunk Ports               : 0
Shared License                 : Disabled
AnyConnect for Mobile          : Disabled
AnyConnect for Cisco VPN Phone : Disabled
AnyConnect Essentials          : Disabled
Advanced Endpoint Assessment   : Disabled
UC Phone Proxy Sessions        : 2
Total UC Proxy Sessions        : 2
Botnet Traffic Filter          : Disabled
This platform has a Base license.
Serial Number: JMX162740GP
Running Activation Key: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Configuration register is 0x100003
Configuration last modified by enable_15 at 13:31:09.309 UTC Wed Jan 22 2014
Jon Marshall
Those commands are NAT using ASA version 8.3 onwards. ASA 8.2 uses the old syle NAT.
You don't have the option of using "any" as the interface and you don't use object network type statements.
Jon
Jon Marshall
Jon
hi ,
thanks alot for reply
plz chekc here , ivre updaed to ios 8.4
plz have a look on my config
https://supportforums.cisco.com/message/4145808#4145808
regards
