10G Switch Product Recommendation
dpsw120
Hello guys i want to upgrade my switch from 1G to 10G 24 port switch.
Can someone give me what cisco switch that has 10G speed with 24port or more.
My existing switch cisco sg350-28p.
Thank you,
Dwi
Reza Sharifi
You can get a "C9300-24UX" switch. This switch will give you 24 Multigigabit Cisco UPOE (100M, 1G, 2.5G, 5G, or 10 Gbps).
These are all 10Gig copper ports.
See table-1 in the Datasheet for all the options:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.html
5 Replies 5
Seb Rupik
Hi there,
I assume you want 10G uplinks and not 24x 10G switchports.
In which case look at any of the catalyst 9300 with the 'X' suffix, such as the C9300L-24T-4X.
cheers,
Seb.
No sir, i want 24port with all 10G/rj45. Any recommendation?
balaji.bandi
The model you mentioned was SMB switches, if you go enterprise switches, looking full Line rate, i would suggest Cat 9500 but it will be expensice for you.
but Cat 9300 UXM has some port 10GB port mGIG support for your needs, not sure do you really need Fully populated 10GB ports of 24 ports, and do you have budget ?
BB
Reza Sharifi
Yes, that's what i want 24port 10G copper. I'll look into it, thank you.
