08-17-2013 05:12 AM - edited 03-07-2019 02:59 PM
hi, SFP port of WS-C3750G-24TS support 10g or not? and please also inform me any other gigabit switch which has upto 4 10g ports.
08-17-2013 06:58 AM
No it won't.
3850 will support up to 4 SFP+ (10 Gbps) per unit.
08-17-2013 07:00 AM
3750G series switches do not support 10Gig interfaces. If you need to have 4 10Gig interfaces, you need a 3850 switch.
it comes with 24 or 48 port 10/100/1000 copper and 4 10Gig fiber interfaces for uplink.
see data sheet below for all models:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps12686/data_sheet_c78-720918.html
08-17-2013 10:02 AM
In addition to Reza and Leo's correct information above, you can also build a stack of 2 (or more) 3750X switches with multiple optional C3KX-NM-10G 2-port modules to get 4 (or more) 10 Gbps ports using 1 RU Catalyst 3000 series switches.
Of course you can also use a 4500X or any of the chassis-based switches (4500 series or 6500 series) or even a Nexus 5000 series.
08-17-2013 05:29 PM
But Marvin this solution would be very expensive since the price of a 3850 is exactly the same as a 3750X. Getting a single 3850 (an an optional 10 Gbps module) would be half the price of getting two 3750X (and two 10 Gbps module).
08-17-2013 09:08 PM
Hi Leo,
True it is more expensive yes but not exactly 2x. I just built a validated configuration in CCW for a 3850 with 4 x 10 GE module. (Note the 4 x 10 GE module is only supported on the 48 port 3850.) I compared it to a pair of 24 port 3750X each with a 2 x 10 GE module. Both with IP services licenses and no service options. The list price of the 3750X in US$ was $27,500 vs. $23,500 for the 3850 configuration. That's ~17% more for the 3750X approach by my figuring. Going with LAN base makes it even closer - $16,398 vs. $15,400 or ~6.5% more.
So yes the 3850 is less expensive and it is a nice shiny new box (with shiny and brand new-ish software - I seem to recall recent posts from this Leo guy saying avoid 15.x ) with the new UADT ASICs and built-in wireless controller (also still a bit buggy) that can be licensed, faster stacking technology with nicer stack cables, etc. The 3750X is a bit more but also more tried and true.
Each customer will have different needs and risk profiles and should choose their gear accordingly as an informed decision.
08-17-2013 09:28 PM
Hi Marvin,
How is everything neighbor?
Reza
08-18-2013 02:34 PM
LOL!
08-19-2013 04:34 PM
Yo Marvin!
Someone rated all of our posts a "3" star.
Either someone knows more than all of us or someone doesn't appreciate our posts.
08-19-2013 04:40 PM
Hi Leo,
Ah well. 3 stars are better than none.
...just 21 more points 'til my Purple Star
p.s. Reza - all is well on the north side of the Toll Road.
08-19-2013 04:46 PM
You're 12 points away now.
08-19-2013 05:22 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Actually there was the (rare) WS-C3750G-16TD which had a single 10g port.
