04-07-2011 09:25 AM - edited 03-06-2019 04:30 PM
I need a switch with at least 8x 10Gb access ports, but I am having issues finding a model that will do this.. the 3560-D seems to be uplink ports only is this correct?
04-07-2011 11:03 AM
If you need 8 10 Gig ports, you can use 4900M with an 8 port 10 Gig module. It is 2RU device
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6021/ps9310/Data_Sheet_Cat_4900M.html
04-07-2011 04:06 PM
3560E-12D can do 10Gb. This model can do Layer 2/Layer 3 per interface.
04-07-2011 04:55 PM
Good info Leo
I did not know there is 3560 with 12 10Gig ports.
Thanks +5
04-07-2011 04:59 PM
Thanks for the ratings, Reza.
Please don't be confused with the 3560E-12SD.
