01-31-2009 07:22 PM - edited 03-06-2019 03:47 AM
<p>Hi,</p>
<p>I bought this 1751 hoping that I can use it to replace my Netgear router. Below is the sho ver. Will this router capable of replacing the Netgear.</p>
<p>cisco1751#sho ver<br />
Cisco Internetwork Operating System Software <br />
IOS (tm) C1700 Software (C1700-K8O3SY7-M), Version 12.2(8)T5, RELEASE SOFTWARE (fc1)<br />
TAC Support: <a href="http://www.cisco.com/tac">http://www.cisco.com/tac</a><br />
Copyright (c) 1986-2002 by cisco Systems, Inc.<br />
Compiled Fri 21-Jun-02 19:24 by ccai<br />
Image text-base: 0x80008108, data-base: 0x80D2EACC</p>
<p>ROM: System Bootstrap, Version 12.2(1r)XE1, RELEASE SOFTWARE (fc1)<br />
ROM: C1700 Software (C1700-Y-M), Version 12.2(13)T1, RELEASE SOFTWARE (fc1)</p>
<p>cisco1751 uptime is 15 hours, 48 minutes<br />
System returned to ROM by power-on<br />
System image file is "flash:c1700-k8o3sy7-mz.122-8.T5.bin"</p>
<p>cisco 1751 (MPC860P) processor (revision 0x600) with 36864K/12288K bytes of memory.<br />
Processor board ID JAD06390282 (3061614917), with hardware revision 0000<br />
MPC860P processor: part number 5, mask 2<br />
Bridging software.<br />
X.25 software, Version 3.0.0.<br />
Basic Rate ISDN software, Version 1.1.<br />
1 Ethernet/IEEE 802.3 interface(s)<br />
1 FastEthernet/IEEE 802.3 interface(s)<br />
1 ISDN Basic Rate interface(s)<br />
1 Virtual Private Network (VPN) Module(s)<br />
32K bytes of non-volatile configuration memory.<br />
16384K bytes of processor board System flash (Read/Write)</p>
<p>Configuration register is 0x2102</p>
<p><br />
Thank you.</p>
01-31-2009 11:11 PM
what kind of internet connection you use: isdn, adsl,...?
02-01-2009 08:38 PM
thanks for the reply. to answer the question is cable internet on a DHCP client.
02-13-2009 08:03 PM
i hope someone out here has a similar set-up that i want to achieve. replacing my netgear router with a 1751 that is connected directly to a cable modem on DHCP client. thanks.
02-18-2009 01:11 PM
cable internet on DHCP client
02-18-2009 04:34 PM
I don't think this is possible. The only ADSL-related WIC cards the 1750 will support are the WIC-1ADSL, WIC-1SHDSL, WIC-1ADSL-I-DG and the WIC-1ADSL-DG.
Cisco 1751 Modular Access Router Data Sheet:
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a0080088719.html
02-18-2009 06:13 PM
thanks for the reply. the data sheet shows on figure 3 is what i want to achieve. how do i configure the 1751?
02-22-2009 01:49 AM
I don't know if this will work for sure but it looks like you will have to connect your cable modem into your ethernet port and configure the ethernet port to receive a DHCP from your cable provider like this:
router(config-if)#ip address dhcp
Then you'll probably want to create a default route towards your ISP (default gateway):
router(config)#ip route 0.0.0.0 0.0.0.0 e0
Configure your fastethernet interface (LAN):
router(config-if)#ip address 192.168.0.1 255.255.255.0
After that you'll probably want to specify set up DHCP on your router:
router(config)#ip dhcp excluded-address 192.168.0.1 (excludes your f0 ip)
router(config)#ip dhcp-pool INSIDECLIENTS
router(config-dhcp)#network 192.168.0.0 255.255.255.0
router(config-dhcp)#default-router 192.168.0.1
router(config-dhcp)#dns-server 4.2.2.2 (or your ISPs DNS server)
routeR(config)#no ip dhcp conflict logging
Then setup PAT:
routeR(config)#access-list 100 permit ip 192.168.0.0 0.0.0.255 any
router(config)#int e0
router(config-if)#ip nat outside
router(config-if)#ip nat inside source list 100 interface e0 overload
router(config)#int f0
I've haven't set this type of configuration up before, but this is where i'd start.
Good luck :)
