1811 and COmcast DHCP trouble
Marley Brown
I have a router 1811 that was configure to use comcast static ip now is need to switched to DHCP.
I have started with a very simple config to try and establish an ip address on f1 or f0 but I can get the 1811 to pick one.
all I have done is:
int f1
ip add dhcp
no shut
if I go to ip int brief I have no IP address. If I do debug dhcp I get it can't get an IP or the IP is not for this device.
Any help would be greatly appreciated.
Reza Sharifi
Hi Marley,
In the global config mode try this command:
"service dhcp"
and test again
If still no connection post the configs for your interfaces.
Reza
Reza
I will try this on Wednesday. I have limited access to Comcast service with DHCP. If you have any other suggestions please let me know and I will try all of it.
Here is my int config:
interface FastEthernet1
description $ETH-WAN$
ip address dhcp
ip virtual-reassembly
duplex auto
speed auto
I am just trying the basics until I can get an IP address.
Thank you,
Marley
zartar911
Hi Marley,
If you have an access-list attached to your interface for incoming traffic, make sure you allow bootpc.
"permit udp any eq bootpc any eq bootpc"
Tim
Tim,
No access list on the interface.
Thank you,
Marley
