1841 at 99% CPU what can I do?
Andy White
Level 3
Level 3
I've never had a router's CPU suddenly hit 99% and just stay like it for hours even after a reboot.  This router really does nothing with regards to CPU, I'm looking at it's CPU history (via SolarWinds Orion NPM software that we use) and it is arounf 1-3% all the time for the past 2 years.
What commands can I use to diagnose the issue?
I did a show debugigng and it seems no debugging is running
9 Replies 9
Sandeep Choudhary
Can you paste the output of this command;:
show processes cpu
see this link:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_tech_note09186a00800a65d0.shtml?referring_site=bodynav
Please rate if it helps.
Peter Paluch
Hi Andy,
Can you see the output of the show process cpu sorted 1m and post it here? This output should tell you the processes whose 1-minute CPU load average is the highest. This should eventually help us see what process consumes the most of your CPU power.
Best regards,
Peter
Thanks guys, it's
97.37%    IP NAT Ager
The routers main purpose is to NAT to be honest.
Hi Andy,
To find out the root cause you can enable netflow in your local lan  interface and find out whats happening with the traffic transactions.
With that you can come to a solid conclusion or atleast get a clue on what is making or hogging the CPU up.
Configure ip route-cache flow under your local lan ethernet interface and make use of show ip cache flow to check the traffic transactions.
Hope the below link helps u out.
http://www.cisco.com/en/US/docs/ios/12_3/switch/command/reference/swi_s1.html#wp1066187
may be its a Buggy IOS, upgrade.?
regds
Maybe a bug, Neflow is already running and shows hardly any traffic.
Memory is up from 20% to 80% too.
Hello Andy
Can you give a     clear ip nat translation *     and see whether the CPU comes down.. and what is the traffic on the outgoin interface show interface < interface name>
Harish.
Hi, I've already clear the table and it still stays at 99%
IOS is old, had a look a newer IOS but there are so many to choose, I'd appreciate if you can help locate a newer one?  Form the below output it would seem that the memory is 128mb and flash 32mb, I tried to see if this current IOS has been deferred but it wasn't listed.
Compiled Fri 30-Nov-07 14:10 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1)
NAT_router uptime is 3 hours, 23 minutes
System restarted at 11:14:50 bst Mon Oct 8 2012
System image file is "flash:c1841-ipbasek9-mz.124-18.bin"
Cisco 1841 (revision 5.0) with 114688K/16384K bytes of memory.
Processor board ID FCZ092822QY
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31744K bytes of ATA CompactFlash (Read/Write)
Hi Andy,
See this link:http://tools.cisco.com/ITDIT/CFN/
Chosse what services you want on router and  decide which IOS u can take.
