1841 Router limiting WAN speed from 50MB to 20MB
Comcast just swapped out our old cable modem with a new DOCIS3 unit and tested the link from the modem with 50MB+ download speeds.
I validated the test by directly connecting to the modem switch port and did speed tests from Comcast business class and dslreport sites with similar results of over 50MB.  The modem is connected to WAN port f0/1 with static ip address.
Tests done on the LAN side of the router all are limited to 20MB range.
Testing directly connected the HWIC switch port on the router also is limited to the 20MB on speed tests.
Any help with this would be appreciated.
Here is my basic info from router:
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
ImagoDei1841 uptime is 1 day, 17 hours, 31 minutes
System returned to ROM by reload at 17:57:02 PST Wed Jun 8 2011
System restarted at 18:01:01 PST Wed Jun 8 2011
System image file is "flash:c1841-advsecurityk9-mz.124-25e.bin"
Cisco 1841 (revision 7.0) with 115712K/15360K bytes of memory.
Processor board ID FTX1135W29K
6 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31488K bytes of ATA CompactFlash (Read/Write)
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
description To ComcastWAN$ETH-WAN$
ip address 173.164.72.xxx 255.255.255.248
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
crypto map clientmap
stephenshaw
