Multilink interface configuration
hamidul.islam
Level 2
Level 2
I will configure Cisco router 3825 at WIC slot 1 to support 2 T1's circuit. We already have aT1 link @ WIC slot 0 of the router which is configured on the serial interface.
I need to know if i configure the following to support the new 2 T1 circuit how would it identify which circuits it is pointing:
config t
interface multilink 1
ip address X.X.X.X  X.X.X.X
no shut
Thanks.
vmiller
Level 11
Level 11
Look at example 9-2 in the following.
http://www.cisco.com/en/US/docs/ios/12_2/dial/configuration/guide/dafppp.html#wp1022210
That should get you started on what needs to be done.
another one
http://www.fnode.com/2009/09/how-to-configure-ppp-multilink/
