Security level confusion !
Jonn cos
Level 4
Level 4
Hi all experts.
I am using ASA 8.0. Following is the simple topology
Pc1--------------------------ASA-------------------------------Pc2
      outside 0                         inside 100
Now what i have read that traffic from higher security level to lower security level is allowed. But when i ping from Pc2 to Pc1, it is not successfull. When i searched a bit more, i came to know that, i still need to apply access-list to allow traffic from 100 to 0.
Which point is correct ? do i explicitly need ACLs to permit traffic from higher level to lower level or is it allowed by default ?
cadet alain
the lower the security level the riskier it is and by default traffic can flow from high to low and return traffic is permitted in the reverse direction for TCP and UDP.
For ICMP you have 2 solutions to enable return traffic from low to high:
-enable ICMP inspection
- configure an ACL permitting echo replies and apply to outside interface inbound.
The first solution is the safest
the 2 ways are explained here: http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094e8a.shtml#topic0
Regards.
Alain.
cadet alain
Regards.
Alain.
Jonn cos
Level 4
Level 4
Ok i have understand why icmp didnt made through. Is there any debug command that can tell me which packet was dropped and why ??
Pls i need to make sure i am good with troubleshooting also. Pls guide me, what debug command will help me figure out why this icmp packets are being blocked.
look at this doc:
http://www.cisco.com/en/US/docs/security/asa/asa83/asdm63/configuration_guide/admin_trouble.html
REgards.
Alain.
