1900 series router not giving out IP adresses
javdakker
Hi there,
I've got a problem with DHCP running on a cisco 1900 series router, 1921 to be precise. The Data VLAN works perfectly, i configured a ip helpder address
and its working. Problem tough is VLAN 20. This is the voice vlan. As u can see in the config below, this has been configured using VRRP and VRF for failover purposes. Anyone that can spot a problem in the configuration? I did more of these configurations, and they all worked fine, just not with this particular router!
As u will notice i deleted all the not needed to know information or i X'ed it!
Thanks in advance!
Jan-Aart
version 15.1
service password-encryption
hostname CAR_LIC_BRO1_RTR001
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip vrf data
rd 6xxxx:10
route-target export 6xxxx:10
route-target import 6xxxx:10
ip vrf voice
rd 6xxxx:20
route-target export 6xxxx:20
route-target import 6xxxx:20
ip dhcp excluded-address vrf voice 10.0.42.1 10.0.42.100
ip dhcp excluded-address vrf voice 10.0.42.200 10.0.42.254
ip dhcp pool CAREAZ_VOICE_VRF_VOICE
vrf voice
network 10.0.42.0 255.255.255.0
default-router 10.0.42.254
lease infinite
no ip domain lookup
license udi pid CISCO1921/K9 sn xxxxxxxxxxxxxxx
username lagarde privilege 15 secret xxxxxxxxxxxxxxxxxxx
redundancy
track 1 interface GigabitEthernet0/0.6 line-protocol
track 2 ip route 0.0.0.0 0.0.0.0 reachability
ip vrf data
track 3 interface GigabitEthernet0/0.7 line-protocol
track 4 ip route 0.0.0.0 0.0.0.0 reachability
ip vrf voice
policy-map custom-shaper-50000Kbps
class class-default
  shape average 48200000
interface Embedded-Service-Engine0/0
no ip address
shutdown
description NAAR_FIBER_NTU
no ip address
duplex auto
speed auto
no keepalive
no cdp enable
description WAN_DATA_VLAN6
encapsulation dot1Q 6
ip vrf forwarding data
pppoe enable group global
pppoe-client dial-pool-number 1
no keepalive
no cdp enable
service-policy output custom-shaper-50000Kbps
description WAN_VOICE_VLAN7
bandwidth 1024
encapsulation dot1Q 7
ip vrf forwarding voice
pppoe-client dial-pool-number 2
no keepalive
no cdp enable
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/0/0
description NAAR SWITCH_VOICE
switchport access vlan 20
no ip address
interface FastEthernet0/0/1
no ip address
interface FastEthernet0/0/2
no ip address
interface FastEthernet0/0/3
description NAAR SWITCH_DATA
no ip address
interface FastEthernet0/1/0
no ip address
interface FastEthernet0/1/1
no ip address
interface FastEthernet0/1/2
no ip address
duplex full
speed 100
interface FastEthernet0/1/3
no ip address
spanning-tree portfast
interface Vlan1
description DATA INTERNET
ip address 10.32.36.2 255.255.255.0
ip helper-address 172.21.0.6
ip virtual-reassembly in
no ip route-cache
ip tcp adjust-mss 1452
vrrp 1 ip 10.32.36.1
vrrp 1 preempt delay minimum 20
vrrp 1 priority 121
vrrp 1 track 1 decrement 20
vrrp 1 track 2 decrement 20
interface Vlan20
description VOICE
ip address 10.0.42.251 255.255.255.0
no ip route-cache
vrrp 2 ip 10.0.42.254
vrrp 2 preempt delay minimum 20
vrrp 2 priority 121
vrrp 2 track 3 decrement 20
vrrp 2 track 4 decrement 20
interface Vlan100
description NATIVE WAN
no ip address
interface Dialer1
description DIALER_VOOR_VLAN_DATA
mtu 1492
ip address negotiated
ip virtual-reassembly out
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username xxxxxxxxxxxx password xxxxxxxxxx
no cdp enable
interface Dialer2
description DIALER_VOOR_VLAN_VOICE
encapsulation ppp
dialer pool 2
dialer-group 2
ppp pap sent-username xxxxxxxxxxxxx password xxxxxxxxxxxxxxx
no cdp enable
router bgp 6xxxx
bgp router-id vrf auto-assign
bgp log-neighbor-changes
address-family ipv4 vrf data
  network 10.32.36.0
  redistribute connected
  neighbor 172.31.255.68 remote-as 2yyyy
  neighbor 172.31.255.68 description Fiber_Main
  neighbor 172.31.255.68 password xxxxxxxxxxxxxxxxxxx
  neighbor 172.31.255.68 activate
  neighbor 172.31.255.68 weight 100
  neighbor 172.31.255.68 prefix-list announce_data out
exit-address-family
address-family ipv4 vrf voice
  network 10.0.42.0
  redistribute static
  neighbor 172.31.255.95 remote-as 2yyyy
  neighbor 172.31.255.95 description Fiber_Main_Voice
  neighbor 172.31.255.95 password xxxxxxxxxxxxxxxxxxxxxx
  neighbor 172.31.255.95 activate
  neighbor 172.31.255.95 weight 100
  neighbor 172.31.255.95 soft-reconfiguration inbound
  neighbor 172.31.255.95 prefix-list announce_voice out
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip prefix-list announce_data description Uitgaand DATA subnet
ip prefix-list announce_data seq 5 permit 10.32.36.0/24 le 32
ip prefix-list announce_data seq 100 deny 0.0.0.0/0 le 32
ip prefix-list announce_voice description Uitgaand VOICE subnet
ip prefix-list announce_voice seq 5 permit 10.0.42.0/24 le 32
ip prefix-list announce_voice seq 100 deny 0.0.0.0/0 le 32
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
control-plane
line con 0
login local
line aux 0
login local
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
end
Message was edited by: Jan-Aart vd Akker
Jeff Van Houten
Level 5
Level 5
You have the svi configured, but have you added vlan 20 to the vlan database?
Julio Carvajal
Hello Jan,
VRPP configuration looks good
DHCP configuration looks good
VRF setup looks good
Interface setup looks good
As Jeff mentioned I will check the layer 2 setup.
Any other question..Sure,,Just remember to rate all of the support answers.
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
When i issue a Show ip int brief i see VLAN20 up up. So its working properly.
Weird thing is that when i configure a static ip on my laptop, and connect to a port on the router, that has switchport access vlan 20 configured, i can not ping the router address either... should be possible. I cant ping the vrrp ip address but neither can i ping the ip address on the vlan.
Any other suggestions?
Jan-Aart van den Akker
