1921 doesn't show commands for VPN configuration
praveenku
I have installed evaluation license for security features in my 1921 router but i still cant see commands to configure VPN. Could anyone please helpe me whats the issue?
some show commands are given below.
PMGC-LONDON#show license
Index 1 Feature: ipbasek9
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
Index 2 Feature: securityk9
        Period left: 8  weeks 4  days
        Period Used: 0  minute  0  second
        License Type: Evaluation
        License State: Active, Not in Use, EULA accepted
        License Priority: Low
Index 3 Feature: datak9
        Period left: Not Activated
        License Type: EvalRightToUse
        License State: Not in Use, EULA not accepted
        License Priority: None
Index 4 Feature: SSL_VPN
        License Count: 0/0  (In-use/Violation)
Index 5 Feature: ios-ips-update
Index 6 Feature: WAAS_Express
PMGC-LONDON(config)#crypto ?
  key  Long term key operations
  pki  Public Key components
PMGC-LONDON#show version
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.1(4)M3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 06-Dec-11 16:02 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
PMGC-LONDON uptime is 15 hours, 7 minutes
System restarted at 18:06:42 UTC Mon Jul 29 2013
System image file is "usbflash0:c1900-universalk9-mz.SPA.151-4.M3.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1921/K9 (revision 1.0) with 491520K/32768K bytes of memory.
Processor board ID FCZ161390T0
2 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
250864K bytes of USB Flash usbflash0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO1921/K9          FCZ161390T0
Technology Package License Information for Module:'c1900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
data          None          None           None
try
Router(config)# license feature securityk9
or
Router(config)# license boot module c1900 technology-package securityk9
Router(config)# license accept end user agreement
Michal
Hi Praveen,
How do you resolve this issue....
Michal,i also stuck in same problem.can you help me for this.
Sandeep Choudhary
HI Praveen,
You would need to obtain the Security feature license in order to configure Secure VPN.
Currently you have "none" for the Security feature:
data          None          None          None
Here is the more information on licensing on 1900 series router:
http://www.cisco.com/en/US/partner/docs/routers/access/1900/hardware/installation/guide/Software_Licenses.html
Hope it helps.
