1921 Router and sub interfaces
joerggrau
I am designing a new connectivity solution to one of our customers and would like to deploy a couple of pairs of 1921 switches as it is pretty low bandwidth traffic.  Now looking ahead I would like to be able to use the same routers for other/future customers.
I have been going over the myriad of docs for IOS 15.0 but I have not been able to find out if 15.0 allows me to use the same GigE port and trunk it into several sub interfaces on separate VLANs.
Does anyone know if this can be done and, if so, where I can find some documentation on it?
Joerg
Nagaraja Thanthry
Subinterfaces is a basic feature and should be supported by all IOS releases
on supported platforms. Here is a document that explains how to create
subinterfaces.
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_examp
le09186a00800949fd.shtml
Hope this helps.
NT
