Bookmark
Subscribe
884
2 Different ip addresses, same mac address
carl_townshend
Hi all
Under what circumstances would I see the same mac address but with 2 ip addresses when doign a shwo arp on my core switch?
cheers
Carl
Rolf Fischer
Level 9
Level 9
Hi Carl,
in your second post you pasted the MAC address (MAC Flap Message), so we know there's a HP Virtual Connect module on the other side. Typically there're running multiple servers on such a module and you see an ARP entry for every server IP address, all using the same MAC.
I'm not familiar with the HP VCs but I think this is default behavior and can be changed if desired.
Best regards
Rolf
