02-08-2024 04:02 AM
The diagram shows that 2 network has the same 192.16.10/24 network. How to make the 2 network communicate with each other.
02-08-2024 05:45 AM
Good option is Option is do NAT overlap IP addresses
use below example :
https://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/13774-3.html
=====️ Preenayamo Vasudevam ️=====
02-08-2024 08:10 AM
Sorry I forgot to mention that the task is not to use Nat
02-09-2024 09:23 AM
Not that i am ware can be done in different way.
02-08-2024 08:30 AM
02-08-2024 05:59 AM
Yes, if you can't change one side or the other, then one side is going to have to be NATTED.
02-08-2024 08:11 AM
@Richard Pidcock wrote:Yes, if you can't change one side or the other, then one side is going to have to be NATTED.
02-08-2024 01:21 PM - edited 02-08-2024 01:30 PM
Do you need the entire /24 on both sides? is it feasible for you to split the range into 2 x /25'?
Or you could create a L2 bridge possibly using a GRE tunnel or https://www.cisco.com/c/en/us/support/docs/ip/layer-two-tunnel-protocol-l2tp/116266-configure-l2-00.html
02-08-2024 07:23 PM
Yes it need to be /24 in both sides that's that task
02-09-2024 04:53 AM
Hmm, cannot NAT, cannot bridge the L2 segment, quite a puzzle. I don't see it being possible. Conceptional you want hosts which may have duplicate IPs to intercommunicate? How would routing work with duplicate subnets?
Be interesting to see if anyone has a solution.
02-09-2024 05:57 AM
I'm with @Joseph W. Doherty, you've got quite the conundrum. I don't really see how to make that work given your constraints. Is this a real world scenario or some type of training lab?
