2 switches 1 router
Hi guys, i'm trying to run 2 switches (2960 POE and other non POE) with 2 subnets on 1 router (cisco 2811).
One is basically only for 7911 phones and the other for CIPC connected to PCs with DHCP from a network router, but I cannot make each subnets to ping themselves. Thanks in advance for your feedback
Attached you can find my run
14 Replies 14
ahmedshoaib
Level 4
Level 4
Hi;
Just want to get more information how's your connectivity of switches & router.
& why you configure the sub-interface on interface F0/0.1, if you want to assign multiple subnet on same interface then use secondary key-word after assigning IP address.
Thanks & Best regards;
Were you trying to configure router on a stick on your router to enable routing between different VLANs ?
If yes, then the config needs to be modified.
Harsha
Hi Harsha, that's what i'm trying to do.
What should be the changes to be done?
Thanks in advance
Hi, what should be the configuration mode that you recommend?
Thanks!
Hi;
Normally Voice & Data Vlan are using different vlan. take a example we are using vlan 1 (Data) and vlan 2 (Voice)
Router Configuration:
interface FastEthernet0/0 description *** Trunk to Switch *** no ip address ! interface FastEthernet0/0.1 description *** Data vlan ***
encapsulation dot1Q 1
ip address 192.168.10.200 255.255.255.0
no shutdown
interface FastEthernet0/0.2
description *** Voice vlan ***
encapsulation dot1Q 2
ip address 10.110.7.40 255.255.255.0
no shut
Switch Configuration:
interface FastEthernet0/0 description *** Trunk to Router *** switchport
switchport mode trunk
switchport trunk encapsulation dot1q (normally this command required on old Cisco switches)
getting this message when entering the ip address config
% 192.168.10.0 overlaps with FastEthernet0/0
and
% 10.110.7.0 overlaps with FastEthernet0/0.1
any ideas?
Hi;
First you need to remove the existing IP address on interface F0/0 & F0/0.1 then apply the configuration.
Just trying to figure it out if that would be my correct setup, attached you can find my current diagram.
Also, the  Fa0/0 should be connected to Data switch right? and Fa0/1 to Voice switch?
Would this setup allow me to configure softphones and hardphones and communicate between them?
Hi;
If you are using separate ports for voice & Data it's also OK. depend on requirement:
If you want to configure the port you need to modify the following:
interface FastEthernet0/0 description *** Data vlan ***
no shutdown
interface FastEthernet0/1
description *** Voice Network ***
no shut
ip route 0.0.0.0 0.0.0.0 192.168.10.1
Thanks for your feedback.
But with that setup I cannot reach my Router from my CIPC phones.
Any ideas? Atthached you can find my show interface file.
Interface FastEthernet0/0
description DATOS
duplex auto
speed auto
encapsulation dot1Q 1 native
ip address 10.110.17.1 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.110.17.1
Hi;
Be remember whenever you are configure sub-interface on Router don't configure any IP Address on physical interface. if you required to configure multiple IP address then use standby ip address. e.g:
ip address 10.110.7.40 255.255.255.0 standby
no shutdown
Hi Ahmedshoaib,
Thanks for your assistance.
Maybe I should reexplain my case.
What i'm trying to do is to connect 2 switches to 1 router.
Switch1: IP: 192.168.10.1 <- ISP Gateway router assigns DHCP to my LAN and my computers which I need to run CIPCs
Switch2: IP: 10.110.17.1 <- gateway which I have connected only phsysical telephones (7911) Working already. No access to internet
What I want to do is to have CIPC and 7911 phones in separate IP ranges and reach the router for outgoing and incoming calls to my E1 service and internal calls from extensions.
Right now, i cannot ping from my computers (192.168.10.1 gateway) to my cisco router or to my 7911 phones (10.110.17.1 gateway)
Thanks for your time and your assistance, already gave you 5 stars
Hi, attached you can find my current config.
Remember that this router has an E1 service that I want to share with both subnets
Thanks to all for your assistance
Hi guys, still with this problem.
Here´s my switch config, just to let you know that the Crypto setting it's not in use
sw1#show runn
Building configuration...
Current configuration : 3170 bytes
version 12.2
no service pad
hostname sw1
boot-start-marker
boot-end-marker
enable secret 5 $1$HUOW$v0QpfdQNMsNJFXZGj1Tor.
enable password cisco123
no aaa new-model
system mtu routing 1500
ip subnet-zero
cluster enable tigo 0
crypto pki trustpoint TP-self-signed-3989089536
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3989089536
revocation-check none
rsakeypair TP-self-signed-3989089536
crypto pki certificate chain TP-self-signed-3989089536
certificate self-signed 01
3082023C 308201A5 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33393839 30383935 3336301E 170D3933 30333031 30303030
35365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 39383930
38393533 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100E6F5 90F94FC9 2E39DE44 437324B9 068067FC DEC259FD 0D7B15BA EF62F550
AA017522 6C37F079 5A3C5A0B 31880C82 AFFFB927 FE4F1603 190746F6 707936ED
0FD0AB12 DC0EC507 59432E27 022329F8 74B562DC 926BA8F9 1F079745 447BE4E2
14C4634E B01AE546 F2C87103 77F15ED8 C868E90D 6984C184 209B04E9 BBC49CD3
61F30203 010001A3 64306230 0F060355 1D130101 FF040530 030101FF 300F0603
551D1104 08300682 04737731 2E301F06 03551D23 04183016 80141677 56D5E11D
5D1B72A0 600500B2 EB2D949C DF4C301D 0603551D 0E041604 14167756 D5E11D5D
1B72A060 0500B2EB 2D949CDF 4C300D06 092A8648 86F70D01 01040500 03818100
BFC6797D E03ABD45 1DC5C1B0 05CD4EDB 5D366749 B6E6D9E3 C2ABECED F4F8E72E
AC1FECAC F598A675 CA1C7E2E DB137718 DDAB0300 4888C9EF 9F429EBA 247343F2
0E7AEE5B FD45DC0A 69523142 FA4D38AB 6E96870F 14EB0244 828D8545 8B07DC2B
194BB58A 1AF36DB8 B234FFFD 6293B2CA 58492D10 6F838D57 2A235BE0 316B2B52
quit
spanning-tree mode pvst
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 192.168.1.10 255.255.255.0
no ip route-cache
interface Vlan2
no ip route-cache
ip http server
ip http secure-server
control-plane
line con 0
exec-timeout 0 0
line vty 0 4
password cisco123
login
line vty 5 15
password cisco123
login
end
