2501 boot problem
dhavaltandel
Level 4
Level 4
Hi all,
i have cisco 2501 router, am getting the eroor as,
Abort at 0x10005BC (PC)
this messege display on terminal and nothing happen.
can any help me out of this to make that router working...?
is there any IOS problem...?
thanks
Dhaval Tandel
Richard Burts
Dhaval
I have seen symptoms like this when the memory was not properly seated because it may have been jarred during moving the router or something.
My suggestion is to power down the router, to open the case, to remove and to reseat the memory (I would probably do the flash also). Then close the case, power up and see if it will boot now.
Rick
Rick
adnan.zafar
Level 3
Level 3
1) change the config register value
How to do this ???
write these commands on rommon mode
o/r 0x2101
i
2) Take back flash form slot and insert it again
Your problem will solved
Hope this may helps you
