2610 ios with crypto key help!!
chasezz1010
Im taking a CCENT/CCNA course going for certif. I bought a 2610 with a WIC1T card from local recycle shop and it only came with the base ios. I'm looking for an IOS that will allow me to create a crypto key so i can set up SSH etc. I've tried to google which IOS file i need to allow me to do so (also to download for free) but haven't found anything that will lead me in the right direction. I dont want anything that i have to pay for because this is for learning purposes and wont ever be used in anything but my home lab that im trying to set up. Any and all help to put me in the right direction is much appreciated.
The current version is as folllows:
IOS (tm) C2600 Software (C2600-IS-M), Version 12.1(5)T8,  RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/cgi-bin/ibld/view.pl?i=support
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Mon 07-May-01 19:18 by ccai
Image text-base: 0x80008088, data-base: 0x8101A6DC
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
ROM: C2600 Software (C2600-IS-M), Version 12.1(5)T8,  RELEASE SOFTWARE (fc1)
router uptime is 47 minutes
System image file is "flash:c2600-is-mz.121-5.T8"
cisco 2610 (MPC860) processor (revision 0x203) with 39936K/9216K bytes of memory.
Processor board ID JAD05190S7D (3702310425)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
--More--
00:47:40: %SYS-5-CONFIG_I: Configured from console 16384K bytes of processor board System flash (Read/Write)
Configuration register is 0x2142
thanks again.
J
Richard Burts
Jeff
I certainly understand your perspective that this router will only be used for learning purposes and that you do not want to pay for an IOS upgrade for it. Unfortunately Cisco does not see it this way. Cisco does not provide any free upgrade for study purposes. There have been lots of discussions about how it is sensible and logical and Cisco should provide support for study purposes. But the current reality is that there is no legitimate way to download an IOS for your router for free.
Rick
Rick
chasezz1010
Thanks for the responce,
I was curious because i got 2 cisco switches from the same place and was able to download older ios versions that supported thw cryptokey functions..
J
Sent from Cisco Technical Support Android App
