Blocking Peer to Peer Applications on LAN
jeevan.koganti
I am facing issues in blocking Peer to Peer applications in LAN. I am using 881 Cisco router and below is the config done. Can anyone help me on this.
class-map match-any sites
match protocol bittorrent
match protocol edonkey
match protocol fasttrack
match protocol gnutella
match protocol kazaa2
match protocol winmx
match protocol skype
policy-map blocksites
class sites
drop
interface vlan1
service-policy input blocksites
Thanks in advance,
Jeevan.
mahmoodmkl
Level 7
Level 7
The config seems to be ok
what is the issue u r facing
have u tried applying the ploicy map in out direction
