2610 Subinterface issue. Able to see cdp neighbours, but unable to ping them
Dmitriy Rybkin
Frequent Visitor
Frequent Visitor
I have a problem with my 2610 router. I have 2950 switch connected to the 2610 router using trunk connection. On the 2610 router when i assigned IP addres 192.168.0.1 to the interface e0/0 i am able to ping 192.168.0.2 -  my Vlan1 interface on the Switch. Then i deleted ip address from e0/0 interface on the router and assigned it to the subinterface e0/0.1 and immediatly i am unable to ping the e0/0.1. subinterface... but here is what i can see throuth the cdp neighbours command:
DR_Switch(config)#do show cdp neigh
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
DR_Router.dr.com
                 Fas 0/2            136           R       2610      Eth 0/0.1
DR_Switch#show cdp entry *
Device ID: DR_Router.dr.com
Entry address(es):
  IP address: 192.168.0.1
Platform: cisco 2610,  Capabilities: Router
Interface: FastEthernet0/2,  Port ID (outgoing port): Ethernet0/0.1
Holdtime : 139 sec
Version :
IOS (tm) C2600 Software (C2600-JSX-M), Version 12.2(26c), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Mon 30-Jul-07 18:03 by ccai
advertisement version: 2
Duplex: half
Management address(es):
DR_Switch#
This is configuration of the interfaces...
(2610 router)
interface Ethernet0/0.1
encapsulation dot1Q 1 native
ip address 192.168.0.1 255.255.255.0
(2950 switch)
interface Vlan1
ip address 192.168.0.2 255.255.255.0
no ip route-cache
________________________________________________
Here is what i did to troubleshoot connection:
DR_Router#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
DR_Router(config)#in e0/0
DR_Router(config-if)#ip address 192.168.0.1 255.255.255.0
DR_Router#ping 192.168.0.2
Sending 5, 100-byte ICMP Echos to 192.168.0.2, timeout is 2 seconds:
DR_Router#conf t
DR_Router(config-if)#no ip address
DR_Router(config)#int e0/0.1
DR_Router(config-subif)#encapsulation dot1Q 1 native
DR_Router(config-subif)#ip address 192.168.0.1 255.255.255.0
Sending 5, 100-byte ICMP Echos to 192.168.0.10, timeout is 2 seconds:
No result.... CAn you help me with this problem?
kcnajaf
Level 11
Level 11
Hi Dmitriy,
Try removing the "native" command from the router configuration and ping.
conf t
int e0/0.1
no encapsulation dot1Q 1 native
Najaf
additionally, make sure on your switch side, the interface(F0/2) must be set to trunk with "sw mo tru & sw tr en do"
Dmitriy Rybkin
Frequent Visitor
Frequent Visitor
I've tried to remove native from encapsulation command and interface F0/2 on the switch is set up as a trunk (dot1Q). No success. I will try to remove vlan files from flash on the switch and the router later on today and create vlans again, maybe thats some sort of a glitch. I dont see any other reasons for it not to work.
kcnajaf
Level 11
Level 11
Hi Dmitriy,
Look at this
Your first Ping
Your second Ping
For your second ping to 192.168.0.2 and ICMP request is send to 192.168.0.10...Check why is this happening on first place and that would nail the problem down
Najaf
Please rate when applicable or helpful !!!
